查看: 16887|回复: 2
TcEng DAK Adapter Installation and Configuration
发表于 2007-8-6 17:20:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Teamcenter Engineering DAK Adapter integrates Teamcenter visualization with the Web Access client and the Teamcenter Portal client. If you want to use Teamcenter visualization with Portal or Web Access, you must install and configure this DAK Adapter.
the attached file is a step-by-step guide for the Teamcenter Engineering DAK Adapter Installation and Configuration
发表于 2007-8-29 09:54:11 | 只看该作者
谢谢。
发表于 2008-5-27 19:29:53 | 只看该作者
thank you very much!
GMT+8, 2025-4-9 03:24 , Processed in 0.023290 second(s), 12 queries , Gzip On, Redis On.
