查看: 19723|回复: 25
【讨论】winxp中打开UGcast
发表于 2002-4-22 14:19:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
怎样正常打开UGcast?
发表于 2002-4-23 17:49:30 | 只看该作者
IE的虚拟机插件没有安装,重装IE,并将虚拟机插件选项开关打开
发表于 2002-4-24 11:12:05 | 只看该作者
winxp中没有java虚拟机。我下载j2re-1_4_0-win-i后,原proe帮助文件的类似问题得到了解决,但UGcast依旧如此。
发表于 2002-4-24 18:35:04 | 只看该作者
IE的虚拟机插件没有安装(VIRTUAL MACHINE),DOWNLOAD FROM MICROSOFT WEB SITE.
发表于 2002-4-25 11:59:59 | 只看该作者
虚拟机 与 winxp没有关系,为ie的一个插件。
发表于 2002-4-26 02:45:05 | 只看该作者
下这个看看:
https://idesign2002.com/2002/ug/jre-1_2_2_008-win.exe
@echo off
rem
rem File Name:  startcast.BAT
rem
rem ************************************************************************
rem
rem This script will set the appropriate variables, run Unigraphics and start
rem a Web Browser on the right hand side of the screen.
rem
rem Copyright (c) 1997-1998
rem Unigraphics Solutions, Cypress, CA 90630
rem All Rights Reserved
rem
rem Input Parameters:
rem
rem None.
rem
rem Revision History:
rem
rem REV   AUTHOR      DATE      COMMENT
rem ===   ======      =======   =======
rem 001   D. Vanfleet Jun98     Modifications for HTML release of V14.0
rem 002   D. Vanfleet Nov98     Initial V15 CAST release
rem 003   D. Vanfleet Jan00     Initial V16 CAST release
rem 003   D. Vanfleet Oct00     Initial V17 CAST release
rem 004   D. Vanfleet Jul01    Initial V18 CAST release
rem
rem
rem
setlocal
set base=%1
set base_dir=%base:"=%
set UGII_BASE_DIR=%base_dir%
if exist .\castenv.bat call .\castenv.bat
echo CAST Parts are in: %UGII_CAST_PARTS%
echo Starting Unigraphics ....
set HOME=%HOMEDRIVE%%HOMEPATH%\
if exist "%HOME%ugcast180" goto AFTER_CREATE_HOME
mkdir "%HOME%ugcast180"
:AFTER_CREATE_HOME
set UGII_DRAFT_EXPRESSIONS_OK=1
:set_display
if "%DISPLAY%" == "" set DISPLAY=LOCALPC:0.0
cd /d %UGII_CAST_PARTS%
start "Title" "%UGII_ROOT_DIR%\"ugraf.exe %*
if ERRORLEVEL 1 goto error_exit
goto normal_exit
rem
:error_exit
pause
:normal_exit
rem Start CAST by calling the castonly.bat file.
echo Starting CAST ....
%UGII_BASE_DIR%\ugcast\castonly.bat
endlocal
@echo on
发表于 2002-4-30 10:38:45 | 只看该作者
昨天下了试试,不行。这是ug18(3cd)中自带的,应该不是castonly.bat的问题吧?我也把它附上来。
发表于 2002-5-3 19:42:55 | 只看该作者
到微软主页下载ie6的java visual machine,大约5M左右
头像被屏蔽
发表于 2002-5-3 22:50:40 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2002-5-7 08:48:30 | 只看该作者
多谢各位指点,答案是:ie6的java visual machine
GMT+8, 2025-2-25 22:33 , Processed in 0.025789 second(s), 12 queries , Gzip On, Redis On.
