查看: 17760|回复: 12
[原创] 我做的一个后处理
发表于 2007-9-23 22:00:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是网上的资料拼成的
发表于 2007-9-23 22:02:15 | 只看该作者
* define private variables:
FORMAT (SEQUENCING)  Seq SubSeq CNTRL_NUM NURBS_DEG count first deg ;
FORMAT (TOOL)        CutterComp FirstTool LastTool ;
FORMAT (COORDINATES) Xold Yold Zold DXcenter DYcenter DZcenter ;
FORMAT (COORDINATES) Zinit Clear Depth CNTRL_X  CNTRL_Y  CNTRL_Z  KNOT_ ;
FORMAT (COORDINATES) Xhome Yhome Zhome ;
FORMAT (COORDINATES) XfirstOrigin YfirstOrigin ZfirstOrigin ;
FORMAT (USER_1)      CurrSubNum ;
FORMAT (coordinates) ORIGOLDI ORIGOLDJ ORIGOLDK ;
* define private flags:
FORMAT (USER_2)      FlagSub FlagSeq FlagSpin;
FORMAT (USER_2)      FirstOriginChange FlagError Flagrotmac  ;
* define private constants:
FORMAT (USER_2)      YES NO ;
* change the format of existing variables:
FORMAT (USER_1)      SUB_NUMBER ;
INTERACTION (USER_1)       "MAIN-PROGRAM-NUMBER"     MainNum     = 100  ;
INTERACTION (TOOL)         "DIACOMP=TOOL+<xx>"       DiaComp     = 50   ;
INTERACTION (USER_1)       "TOOL-CHANGE-PROGRAM"     ChangeTool  = 8000 ;
INTERACTION (CHARACTER)    "SEQUENCING<Y/N>"         NumYN       = "N"  ;
INTERACTION (SEQUENCING)   "SEQUENC-START"           SeqStart    = 10   ;
INTERACTION (SEQUENCING)   "SEQUENC-INCR."           SeqIncr     = 10   ;
INTERACTION (CHARACTER)    "SUBROUTINES<Y/N>"        Sub         = "N"  ;
INTERACTION (USER_1)       "SUB-PROGRAM-NUMBER"      StartSubNum = 1000 ;
NON_MODAL  ALL_VAR;
MODAL      X_CURPOS Y_CURPOS Z_CURPOS ;
MODAL      LIN_MOV CIRC_MOV MCH_FEED SPIN_SPEED SPIN_DIR MCH_COOL MCH_DWELL;
MODAL      CUTCOM_ON  CUTCOM_OFF ;
MODAL      CYC_DEPTH CYC_PECK CYC_DWELL CYC_RETR CYC_CLEAR Depth Clear NURBS_MOV;
IDENTICAL  X_CURPOS X_ENDPT ;
IDENTICAL  Y_CURPOS Y_ENDPT ;
NEW_LINE_IS $ ;
      IF_SET (FlagSeq _EQ_ NO)
         OUTPUT \J ;
      ELSE
         IF_SET (FlagSub _EQ_ NO)
            OUTPUT \J "N" Seq ;
            Seq = Seq + SeqIncr ;
         ELSE
            OUTPUT \J "N" SubSeq ;
            SubSeq = SubSeq + SeqIncr ;
         END_IF ;
      END_IF ;
BEGINNING OF TAPE:
      YES              = 1 ;
      NO               = 0 ;
      Seq              = SeqStart ;
      FlagSeq = NO ;
      FlagSub = NO ;
      IF_SET (NumYN _EQ_ "y") FlagSeq = YES ; END_IF ;
      IF_SET (NumYN _EQ_ "Y") FlagSeq = YES ; END_IF ;
      IF_SET (Sub   _EQ_ "y") Sub     = "Y" ; END_IF ;
      IF_SET (Sub   _EQ_ "Y")
         SET_OFF NO_SUBROUT ;
      ELSE
         SET_ON  NO_SUBROUT ;
      END_IF ;
*-----Unit matrix (MUST be input in this order !!!)
      ROT_MAT1   = 1.0 ; ROT_MAT2   = 0.0 ; ROT_MAT3   = 0.0 ;
      ROT_MAT4   = 0.0 ; ROT_MAT5   = 1.0 ; ROT_MAT6   = 0.0 ;
      ROT_MAT7   = 0.0 ; ROT_MAT8   = 0.0 ; ROT_MAT9   = 1.0 ;
*-----shift all data according to the MCHINE ZERO indicated by the
*     user in the POSTPR interaction
      TRANS_MATX = 0 - X_MACH  ;
      TRANS_MATY = 0 - Y_MACH  ;
      TRANS_MATZ = 0 - Z_MACH  ;
*-----shift the HOME according to the MCHINE ZERO indicated by the
      Xhome = X_HOME - X_MACH  ;
      Yhome = Y_HOME - Y_MACH  ;
      Zhome = Z_HOME - Z_MACH  ;
*-----tool location is HOME
      Xold = X_HOME ;
      Yold = Y_HOME ;
      Zold = Z_HOME ;
*-----For 1st ORIGIN CHANGE
      FirstOriginChange = YES ;
      MCH_FEED   = 9999 ;
*-----output
      IF_SET (FlagSeq _EQ_ YES )
         OUTPUT "%" \J "O" MainNum  ;
      ELSE
         OUTPUT " %" \J " O" MainNum  ;
      END_IF ;
*--For the first origin change
   ORIGOLDI=0 ; ORIGOLDJ=0 ; ORIGOLDK=1 ;
   flagrotmac = no ;
BEGINNING OF PROC:
      KEEP   PROC_NAME ;
      SET_ON MCH_COOL ;
      FlagSub = NO ;
      SubSeq  = SeqStart ;
END OF TAPE:
      IF_SET (FirstTool _NE_ LastTool)
         OUTPUT $ " T" NEXT_TOOL " M98 P" ChangeTool;
      END_IF ;
      OUTPUT $ " M30 " ;
      OUTPUT $ " (文件名称"  PART_NAME   ".pfm)" ;
*-----user define batch file------
      PRINT0 \J "@ECHO OFF" ;
      PRINT0 \J "MD\NC\" PART_NAME ;
      PRINT0 \J "MOVE " PART_NAME "." TP_NAME ".DEMO \NC\" PART_NAME "\" TP_NAME "--" CURR_NAME ".DEMO > NUL" ;
END OF FILE:
         OUTPUT \J "%" ;
      ELSE
         OUTPUT \J " %" ;
      END_IF ;
FEED:
      KEEP MCH_FEED ;
SPIN:
      KEEP SPIN_SPEED ;
COOLANT:
      KEEP MCH_COOL ;
DWELL:
      KEEP MCH_DWELL ;
CUTTER COMPENSATION:
      KEEP  CUTCOM_ON ;
CUTTER COMPENSATION: COFF:
      KEEP  CUTCOM_OFF ;
TOOL CHANGE: FIRST:
      SET_ON  SPIN_SPEED SPIN_DIR ;
*-----save first tool number
      FirstTool = CURR_TOOL ;
      LastTool  = CURR_TOOL ;
*-----tool cutter compensation register number
      CutterComp = CURR_TOOL +  DiaComp ;
*-----assuming 1st tool is in the spindle, there is no need
*     for tool change)
*     OUTPUT $ " T" CURR_TOOL ;
*-----more then one tool in this run of the Post Processor
      IF_SET (NEXT_TOOL _NE_ CURR_TOOL)
         OUTPUT $ " M00 " ;
         OUTPUT $ " 本程式中有2把以上刀具,请通知编程" ;
      END_IF ;
*-----standard tool change commands. (assuming 1st tool is in
      OUTPUT $ " ( " CURR_NAME " )" ;
      OUTPUT $ " ( 刀径=" DIAMETER_ " )" ;
      OUTPUT $ " ( R角=" TOOL_RAD ") " ;
      OUTPUT $ " G90 G80 G00 G17 G40 " ;
      OUTPUT $ " Z" Zhome " S" SPIN_SPEED " " SPIN_DIR ;
TOOL CHANGE:
*-----tool change command (by using an internal tool change
*     subroutine)
         OUTPUT $ " M00 " ;
         OUTPUT $ " 以下程式必须用下面的刀具加工" ;
TOOL CHANGE: LAST:
*-----save last tool number
*     OUTPUT $ " T" CURR_TOOL " M98 P"  ChangeTool ;
*-----the last tool is the same as the first tool
         OUTPUT $ " M00 " ;
      END_IF ;
[ 本帖最后由 平常心 于 2007-9-23 22:06 编辑 ]
发表于 2007-9-23 22:03:18 | 只看该作者
下面部分什么也没动
[ 本帖最后由 平常心 于 2007-9-23 22:10 编辑 ]
发表于 2007-9-23 22:19:36 | 只看该作者
DFPOST
发表于 2007-9-23 22:20:22 | 只看该作者
下来看看,先谢了~!
发表于 2007-9-23 22:22:03 | 只看该作者
请高手指点,我还没用,看不懂的就请不要用了
[ 本帖最后由 平常心 于 2007-9-24 06:51 编辑 ]
发表于 2007-9-24 07:57:36 | 只看该作者
看来不错哦
安全不安全呀?
发表于 2007-9-24 22:03:07 | 只看该作者
刀具名中不能有空格(如25R5 F),否则不能实现批处理
发表于 2007-9-26 18:11:29 | 只看该作者
先下了
发表于 2007-9-26 18:31:49 | 只看该作者
不错,已下。要是把 *.DEMO      改成 *.NC ,会更好一点。
GMT+8, 2025-3-13 02:26 , Processed in 0.029694 second(s), 10 queries , Gzip On, Redis On.
