查看: 26211|回复: 43
[原创] 宏之深度探讨(1)
发表于 2007-9-29 22:19:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
关于录宏,已有很多教程,怎么录宏就不讲了。
讲讲我以前的做法,如何修改宏。
参与人数 1技术 +1 收起 理由
进明 + 1 教程做的非常棒!
发表于 2007-9-29 22:19:43 | 只看该作者
UG的宏,其实也就是一些代码组成,而且很简单,
只要仔细观察下就可以明白!
随便录个宏,然后用记事本打开即可看到宏的代码,
看下面这段,实现的是功能是  选择一个实体,然后平移10,然后删除。
NX 3.0.0.21
Macro File: D:\11.macro
Macro Version 7.30
Macro List Language and Codeset: simplified chine 13
Created by user on Sat Sep 29 22:22:34 2007
Part Name Display Style: $FILENAME
Selection Parameters 1 2 0.229527 1
Display Parameters 0.900000 11.811024 6.307087 -1.000000 -0.534000 1.000000 0.534000
RESET
MENU, 0, UG_EDIT_TRANSFORM UG_GATEWAY_MAIN_MENUBAR !
DIALOG_BEGIN "Persistent Dialog" 137000
DIALOG_PERSISTENT_END 137000
DIALOG_BEGIN "Transform" 5002
BEG_ITEM  1 (1 WIDE 5002) = ""  ! Name
BEG_ITEM  5 (1 BLO  5002) = -1  !
BEG_ITEM  7 (1 CTOL 5002) = 1  !
BEG_ITEM 10 (1 OPTM 5002) = 3  ! Inside/Crossing
BEG_ITEM 12 (1 BLO  5002) = -1  !
BEG_ITEM 13 (1 BLO  5002) = -1  !
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
CURSOR_EVENT 1001 3,1,100 ! single_pt, mb1/0+0, U_Sel_sngl (T+:0+0)
CPOS 3.46874243296038,6.07488192341384,3.50063650704503
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
OK 0 5002 ! OK Callback
ASK_ITEM  1 (1 WIDE 5002) = ""  ! Name
END_ITEM  1 (1 WIDE 5002) = ""  ! Name
END_ITEM  5 (1 BLO  5002) = -1  !
END_ITEM  7 (1 CTOL 5002) = 1  !
END_ITEM 10 (1 OPTM 5002) = 3  ! Inside/Crossing
END_ITEM 12 (1 BLO  5002) = -1  !
END_ITEM 13 (1 BLO  5002) = -1  !
DIALOG_END -2, 0 ! Transform: OK
DIALOG_BEGIN "gt101" 0
DIALOG_END 0, 0 ! gt101: 平移
FOCUS CHANGE IN 1
DIALOG_END 0, 1 ! gt101: 增量
FOCUS CHANGE IN 1
DIALOG_BEGIN "gt107" 0
BEG_ITEM  0 (1 REAL 0) = 0.0000000000000000  ! DXC
BEG_ITEM  1 (1 REAL 0) = 0.0000000000000000  ! DYC
BEG_ITEM  2 (1 REAL 0) = 0.0000000000000000  ! DZC
END_ITEM  0 (1 REAL 0) = 0.0000000000000000  ! DXC
END_ITEM  1 (1 REAL 0) = 0.0000000000000000  ! DYC
END_ITEM  2 (1 REAL 0) = 10.0000000000000000  ! DZC
DIALOG_END -2, 0 ! gt107: OK
FOCUS CHANGE IN 1
DIALOG_END 0, 5 ! gt101: 移动
FOCUS CHANGE IN 1
DIALOG_END -3, 0 ! gt101: CANCEL
FOCUS CHANGE IN 1
MENU, 0, UG_EDIT_DELETE UG_GATEWAY_MAIN_MENUBAR !
DIALOG_BEGIN "Class Selection" 5002
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
CPOS 5.54679050646693,10.8042327113943,3.50063650704503
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
DIALOG_END -2, 0 ! Class Selection: OK
[ 本帖最后由 春泉 于 2007-9-29 22:28 编辑 ]
发表于 2007-9-29 22:19:54 | 只看该作者
NX 3.0.0.21
Macro Version 7.30
前面为基本信息,比如版本,语言,如果你是NX3录的宏,假如你想移植到NX4,那么把第一句改为对应的NX4的版本号。
Macro List Language and Codeset: simplified chine 13,如果是中文下录的,要用在英文UG下,试试把simplified chine 改为english.
RESET
//表示使用了什么菜单下的什么命令,可以很清楚的看到我使用了"Transform"
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
对应"Transform"指令弹出的选择器,BEG_ITEM,就是gegin(开始),也就是刚弹出的选择器的初始状态,
END_ITEM,自然也就是结束状态,有很多个BEG_ITEM,对应与选择器上的每个BUTTON,比如这一句,
BEG_ITEM 10 (1 OPTM 5002) = 3  ! Inside/Crossing   ,对应于“内部/交叉”,假如你在选择器里改为了内部,
那么 END_ITEM 10 (1 OPTM 5002) = 3  ! Inside/Crossing这一句结束语句应该是 END_ITEM 10 (1 OPTM 5002) = 3  ! Inside
DIALOG_END -2, 0 ! Transform: OK    //选择成功
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
//一样对应界面对话框里的每一项,
DIALOG_END 0, 5 ! gt101: 移动  这一句表示我选择的是“移动”
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FOCUS CHANGE IN 1
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
//MENU, 0, UG_EDIT_DELETE UG_GATEWAY_MAIN_MENUBAR ! ,
当又遇到MENU,表示开始一个新的命令,UG_EDIT_DELETE 表示我们选择了DELETE(删除)指令。
后面的每一句又是对应对话框里的每一个选项。 BEG是初始, END是结束状态。
[ 本帖最后由 春泉 于 2007-9-29 23:12 编辑 ]
发表于 2007-9-29 22:20:08 | 只看该作者
理解这些指令和它的过程有什么好处?
我常用的地方:
1。别人录的宏,如果你没法在自己电脑上运行,可以直接用记事本打开,看下他使用了哪些指令等信息,就可以推断出他的思路,实现过程。
2。自己录宏的时候,如果过程比较长,比如你想录个自动刀路,中间忘记了一步,怎么办?我的做法是不管中间的,继续录完,然后再录一个宏,只录中间漏掉的,然后把对应的代码填入第一个宏对应的位置。
3。录相同的宏,只是中间参数不同,那么你只要录一个,把参数分别改改就可以避免重复劳动了。
[ 本帖最后由 春泉 于 2007-9-29 23:07 编辑 ]
发表于 2007-9-29 23:19:53 | 只看该作者
支持高人出招!
宏不太懂,学习......
发表于 2007-9-29 23:22:53 | 只看该作者
楼主继续,强烈支持!
发表于 2007-9-30 10:14:44 | 只看该作者
顶!强烈顶!
发表于 2007-9-30 10:30:11 | 只看该作者
强贴
留名
发表于 2007-9-30 11:21:27 | 只看该作者
支持继续深入下去
发表于 2007-9-30 13:17:54 | 只看该作者
强烈支持,讲讲关于宏得资料.
GMT+8, 2025-4-26 04:24 , Processed in 0.023339 second(s), 12 queries , Gzip On, Redis On.
