查看: 16369|回复: 5
【求助】加工中转角减速的设定
发表于 2002-4-23 14:43:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教:
     加工中转角的减速的参数是怎么设的
发表于 2002-4-24 08:50:23 | 只看该作者
corner里面如图:
发表于 2002-4-24 08:57:00 | 只看该作者
length:Length allows you to determine the distance along which the tool will slow down by specifying One of the following two options.
Previous Tool indicates that the length of the slowdown move is determined either by the diameter of the previous tool or any diameter you enter in the Tool Diameter field. Slowdown begins and ends at the points of tangency of the tool diameter and the part geometry.
Percent Tool indicates that the length of the slowdown move is determined by a percentage of the current tool diameter; you enter the percentage in the % Tool Diameter field. Slowdown begins and ends at the points of tangency of the tool diameter and the part geometry.
发表于 2002-4-24 08:57:31 | 只看该作者
Slowdown%
Slowdown% determines the slowest feed rate during slowdown. It is a percent of the present feed rate. For example, if the current feed rate is 30 ipm and this option is set to 10 %, then the Slowdown Feed Rate will step down to 3 ipm before accelerating
发表于 2002-4-24 08:59:22 | 只看该作者
Number Of Steps
Number Of Steps allows you to set the abruptness of slowdown. The greater the number, the more even the slowdown. The feed rate reduction per step is:
(100% - Slowdown %) / No. of Steps.
The number of acceleration steps is approximately one-half of the number of deceleration steps. In other words, the tool accelerates faster than it decelerates. The following figure shows use of Slowdowns with several other option setting, and Number Of Steps = 5.
发表于 2002-4-24 09:00:00 | 只看该作者
详见ug帮助,
GMT+8, 2025-4-24 12:15 , Processed in 0.038494 second(s), 13 queries , Gzip On, Redis On.
