查看: 15546|回复: 1
[求助] 请大虾帮我看看这几行程序
发表于 2007-10-16 22:05:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的目标是找到face,读出指定u v 处face的参数
#include <uf.h>
#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
#        include <strstream>
#   include <iostream>
        using std:strstream;
        using std::endl;
        using std::ends;
        using std::cerr;
#else
#        include <strstream.h>
#   include <iostream.h>
#endif
#include "test.h"
#include <uf.h>
#include <uf_modl.h>
#include <uf_part.h>
#include <uf_defs.h>
// Main routine
extern void main( char argc, char *argv[] )
    /* Initialize the API environment */
    int errorCode = UF_initialize();
    if ( 0 == errorCode )
        /* TODO: Add your application code here */
tag_t body_id;/* <I>      Face identifier.       */
double param[2];/* <I>    Parameter (u,v) on face (param[2]).             */
double point[3];/* <O>            Point at parameter (point[3]).               */
double u1[3];/* <O>             First derivative in U (u1[3]).             */
double v1[3];/* <O>             First derivative in V (v1[3]).             */
double u2[3];/* <O>             Second derivative in U (u2[3]).             */
double v2[3];/* <O>             Second derivative in V (v2[3]).             */
double unit_norm[3];/* <O>                    Unit face normal (unit_norm[3]).                    */
double radii[2];  /* <O>                Principal radii of curvature (radii[2]).                */
UF_PART_load_status_t error_status;
uf_list_p_t face_list;
double wn;
int num;
UF_MODL_create_list(&face_list);
UF_PART_open("D:\\2.prt",&body_id,&error_status);
UF_MODL_ask_body_faces(body_id,&face_list);
UF_MODL_ask_list_count(face_list,&num);
param[0]=0.5;
param[1]=0.5;
UF_MODL_ask_face_props(body_id,param,point,u1,v1,u2,v2,unit_norm,radii);
        /* Terminate the API environment */
        errorCode = UF_terminate();
    /* Print out any error messages */
    PrintErrorMessage( errorCode );
/* PrintErrorMessage
**     Prints error messages to standard error. */
static void PrintErrorMessage( int errorCode )
    if ( 0 != errorCode )
        /* Retrieve the associated error message */
        char message[133];
        UF_get_fail_message( errorCode, message );
        /* Print out the message */
        // Construct a buffer to hold the text.
        ostrstream error_message;
        // Initialize the buffer with the required text.
        error_message << endl
                      << "Error:" << endl
                      << message
                      << endl << endl << ends;
            // Write the message to standard error
        cerr << error_message.str();
请大虾指点,我建了一个b-splines surface试的,发现读不出来
所以加了
来test一下
结果发现num=0
发表于 2007-10-17 07:50:38 | 只看该作者
我们还没教到UG编程,很佩服你会用宏程序,
GMT+8, 2025-4-22 04:32 , Processed in 0.021132 second(s), 11 queries , Gzip On, Redis On.
