查看: 23913|回复: 25
[原创] UG4.0 与 MasterCAM 颜色对照
发表于 2007-10-19 12:39:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1、适用对象:UG4.0 拆公,MasterCAM 走刀路;
2、UG4.0总共有216种颜色,而MasterCAM 是16/256色;
3、有部分UG颜色导入到MasterCAM时重复,比如 UG 的第11、82、113,对应的颜色都是98;
4、明细:
        UG4.0                MasterCAM9.1
        U.1                M.161
        U.2                M.120
        U.3                M.117
        U.4                M.182
        U.5                M.180
        U.6                M.99
        U.7                M.57
        U.8                M.157
        U.9                M.97
        U.10                M.149
        U.11                M.98
        U.12                M.185
        U.13                M.188
        U.14                M.118
        U.15                M.156
        U.16                M.30
        U.17                M.31
        U.18                M.32
        U.19                M.33
        U.20                M.34
        U.21                M.35
        U.22                M.36
        U.23                M.37
        U.24                M.38
        U.25                M.39
        U.26                M.40
        U.27                M.41
        U.28                M.43
        U.29                M.44
        U.30                M.45
        U.31                M.11
        U.32                M.46
        U.33                M.47
        U.34                M.48
        U.35                M.49
        U.36                M.10
        U.37                M.15
        U.38                M.51
        U.39                M.52
        U.40                M.53
        U.41                M.54
        U.42                M.14
        U.43                M.56
        U.44                M.57
        U.45                M.58
        U.46                M.59
        U.47                M.60
        U.48                M.61
        U.49                M.63
        U.50                M.64
        U.51                M.65
        U.52                M.66
        U.53                M.67
        U.54                M.68
        U.55                M.69
        U.56                M.70
        U.57                M.71
        U.58                M.72
        U.59                M.73
        U.60                M.74
        U.61                M.75
        U.62                M.76
        U.63                M.77
        U.64                M.78
        U.65                M.79
        U.66                M.80
        U.67                M.81
        U.68                M.82
        U.69                M.83
        U.70                M.84
        U.71                M.85
        U.72                M.86
        U.73                M.89
        U.74                M.90
        U.75                M.91
        U.76                M.92
        U.77                M.93
        U.78                M.94
        U.79                M.95
        U.80                M.96
        U.81                M.97
        U.82                M.98
        U.83                M.99
        U.84                M.100
        U.85                M.101
        U.86                M.102
        U.87                M.103
        U.88                M.104
        U.89                M.105
        U.90                M.106
        U.91                M.108
        U.92                M.109
        U.93                M.111
        U.94                M.113
        U.95                M.114
        U.96                M.115
        U.97                M.116
        U.98                M.70
        U.99                M.118
        U.100                M.119
        U.101                M.119
        U.102                M.121
        U.103                M.122
        U.104                M.124
        U.105                M.125
        U.106                M.126
        U.107                M.127
        U.108                M.128
        U.109                M.130
        U.110                M.132
        U.111                M.133
        U.112                M.135
        U.113                M.98
        U.114                M.138
        U.115                M.139
        U.116                M.140
        U.117                M.141
        U.118                M.142
        U.119                M.149
        U.120                M.144
        U.121                M.145
        U.122                M.146
        U.123                M.147
        U.124                M.148
        U.125                M.149
        U.126                M.150
        U.127                M.152
        U.128                M.154
        U.129                M.155
        U.130                M.156
        U.131                M.157
        U.132                M.158
        U.133                M.160
        U.134                M.109
        U.135                M.162
        U.136                M.163
        U.137                M.164
        U.138                M.203
        U.139                M.166
        U.140                M.167
        U.141                M.168
        U.142                M.169
        U.143                M.118
        U.144                M.164
        U.145                M.172
        U.146                M.173
        U.147                M.174
        U.148                M.175
        U.149                M.176
        U.150                M.177
        U.151                M.178
        U.152                M.179
        U.153                M.180
        U.154                M.181
        U.155                M.182
        U.156                M.183
        U.157                M.184
        U.158                M.185
        U.159                M.186
        U.160                M.187
        U.161                M.182
        U.162                M.189
        U.163                M.190
        U.164                M.191
        U.165                M.192
        U.166                M.186
        U.167                M.195
        U.168                M.196
        U.169                M.197
        U.170                M.198
        U.171                M.191
        U.172                M.200
        U.173                M.202
        U.174                M.204
        U.175                M.205
        U.176                M.206
        U.177                M.207
        U.178                M.161
        U.179                M.211
        U.180                M.213
        U.181                M.13
        U.182                M.214
        U.183                M.215
        U.184                M.216
        U.185                M.217
        U.186                M.12
        U.187                M.218
        U.188                M.219
        U.189                M.221
        U.190                M.222
        U.191                M.223
        U.192                M.224
        U.193                M.227
        U.194                M.228
        U.195                M.229
        U.196                M.230
        U.197                M.231
        U.198                M.232
        U.199                M.233
        U.200                M.235
        U.201                M.236
        U.202                M.237
        U.203                M.239
        U.204                M.240
        U.205                M.242
        U.206                M.243
        U.207                M.244
        U.208                M.246
        U.209                M.248
        U.210                M.249
        U.211                M.9
        U.212                M.250
        U.213                M.252
        U.214                M.253
        U.215                M.255
        U.216                M.10
    END
参与人数 1技术 +1 收起 理由
hover08ms + 1 多谢分享!
发表于 2007-10-20 10:34:24 | 只看该作者
谢了,有点用
发表于 2007-10-21 22:32:47 | 只看该作者
谢了
发表于 2007-10-22 09:51:59 | 只看该作者
感谢LZ,学习了。。。。。
发表于 2007-10-22 09:56:51 | 只看该作者
感谢LZ
发表于 2007-10-27 21:51:12 | 只看该作者
各位,我初次进来,请多关照
发表于 2007-10-27 21:54:16 | 只看该作者
各位,我初次进来,对UG分模所知少,请多关照,
头像被屏蔽
发表于 2007-10-28 20:04:53 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2007-10-31 19:56:59 | 只看该作者
好不好啊.
发表于 2007-11-1 08:41:09 | 只看该作者
谢谢分享,收了
GMT+8, 2025-4-23 17:11 , Processed in 0.029346 second(s), 14 queries , Gzip On, Redis On.
