查看: 16270|回复: 3
[求助] 如图所示
发表于 2007-11-5 09:58:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的后处理里无法输出螺旋刀路,这样处理出来的程序不但大,而且在机床上走起来也不顺畅,本人对后处理的修改不是很懂,希望懂后处理的师傅能帮改一下吗,谢谢!(后处理只有两个文件,现传上)
发表于 2007-11-5 11:14:51 | 只看该作者
打开你要用的后处理,TCL格式的那个,然后搜索proc PB_start_of_program 图片(1)
把PB_CMD_init_helix加在图片中的位置.
然后把这一段加在图片(2)的位置应该也行的 ,自己搞一下看看.
proc PB_CMD_init_helix { } {
uplevel #0 {
# This procedure will be executed automatically at the start of program and
# anytime it is loaded as a slave post of a linked post.
# This procedure can be used to enable your post to output helix.
# You can choose from the following options to format the circle
# block template to output the helix parameters.
set mom_sys_helix_pitch_type        "rise_radian"
# The default setting for mom_sys_helix_pitch_type is "rise_radian".
# This is the most common.  Other choices are:
#    "rise_radian"              Measures the rise over one radian.
#    "rise_revolution"          Measures the rise over 360 degrees.
#    "none"                     Will suppress the output of pitch.
#    "other"                    Allows you to calculate the pitch
#                               using your own formula.
# This custom command uses the block template circular_move to output
# the helix block.  If your post uses a block template with a different
# name, you must edit the line that outputs the helix block.
#  The following variable deines the output mode for helical records.
#  FULL_CIRCLE  -- This mode will output a helix record for each 360
#                  degrees of the helix.
#  QUADRANT  --    This mode will output a helix record for each 90
#  LINEAR  --      This mode will output the entire helix as linear gotos.
#  END_POINT --    This mode will assume the control can define an entire
#                  helix in a single block.
   set mom_kin_helical_arc_output_mode LINEAR
   MOM_reload_kinematics
proc MOM_helix_move { } {
   global mom_pos_arc_plane
   global mom_sys_cir_vector
   global mom_sys_helix_pitch_type
   global mom_helix_pitch
   global mom_prev_pos mom_pos_arc_center
   global PI
   switch $mom_pos_arc_plane {
      XY { MOM_suppress once K ; set cir_index 2 }
      YZ { MOM_suppress once I ; set cir_index 0 }
      ZX { MOM_suppress once J ; set cir_index 1 }
   switch $mom_sys_helix_pitch_type {
      none { }
      rise_revolution { set pitch $mom_helix_pitch }
      rise_radian { set pitch [expr $mom_helix_pitch / ($PI * 2.0)]}
      other {
#        Place your custom helix pitch code here
      default { set mom_sys_helix_pitch_type "none" }
   MOM_force once X Y Z
   if {$mom_sys_helix_pitch_type != "none"} {
      MOM_force once I J K
      switch $mom_sys_cir_vector {
         "Vector - Arc Center to Start" {
            set mom_prev_pos($cir_index) $pitch
            set mom_pos_arc_center($cir_index) 0.0
         "Vector - Arc Start to Center" {
            set mom_prev_pos($cir_index) 0.0
            set mom_pos_arc_center($cir_index) $pitch
         "Unsigned Vector - Arc Center to Start" {
         "Vector - Absolute Arc Center" {
# You may need to edit this line if you output more than one block
# or if you have changed the name of your circular_move block template
   MOM_do_template circular_move
} ;# MOM_helix_move
} ;# uplevel
[ 本帖最后由 一片云 于 2007-11-5 11:18 编辑 ]
参与人数 1技术 +1 收起 理由
进明 + 1
发表于 2007-11-5 12:00:25 | 只看该作者
然后出来就是有R的了?
发表于 2007-11-10 17:00:18 | 只看该作者
[quote]原帖由 一片云 于 2007-11-5 11:14 发表
打开你要用的后处理,TCL格式的那个,然后....................
谢谢一片云兄,但是直接在网页上拷贝好像不行,(如图),能否抽时间帮我改一下,谢谢
GMT+8, 2025-7-31 18:34 , Processed in 0.065401 second(s), 13 queries , Gzip On, Redis On.
