查看: 29544|回复: 28
【求助】执行NC后置处理器出错
发表于 2002-4-24 14:48:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Windows NT 的Dr.Watson 应用程序出错,产生应用程序错误日志 javaw.exe 意外错误:访问冲突(0XC0000005),地址:(0X500BF974)。
机器配置:主板:佰钰 4PX266 VIA PX266(DDR) ;RAM:三星256M DDR
              CPU:PIV 1.6G(478)
发表于 2002-4-24 15:08:49 | 只看该作者
               CPU:PIV 1.6G(478)
你可能用GPost做後處理, 對吧!如果是用Surfcam請告知,我會Upload上去
Description
On a Pentium 4 W2K workstation, selecting #Applications #NC Post Processor in Pro/ENGINEER causes a PROGRAM ERROR dialog box to appear with the following message:
"javaw.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created."
On a Pentium 4 NT workstation, selecting #Applications #NC Post Processor in Pro/ENGINEER causes a javaw.exe-APPLICATION ERROR dialog box to appear with the following message:
"The instruction at "0x500bf974" referenced memory at "0x00000e7f". The memory could not be "read"."
In both these cases GPOST will not launch.
Alternate Technique
Download Java Runtime Environment 1.2.2_008 from https://java.sun.com/products/jdk/1.2/jre/download-windows.html and install it in the following directory:
\i486_nt\gpost\ncjlibs\Jre\1.2
Reboot the workstation. GPOST can then be launched by selecting #Applications #NC Postprocessor.
Resolution
This issue will be resolved in a future release of Pro/ENGINEER.
以上由Pro-E論壇轉貼. --- Boby壇主的帖
发表于 2002-4-24 16:53:53 | 只看该作者
    谢谢sinderal!!!!!  我的操作系统是WINNT4.0SP6中文版,找不到您说的Download Java Runtime Environment 1.2.2_008 。
发表于 2002-4-24 17:21:51 | 只看该作者
Download Java Runtime Environment 1.2.2_011也應該可以!
发表于 2002-4-25 22:22:45 | 只看该作者
把\i486_nt下的woptfile.exe和optfile.exe互换名字也可用,但定制后处理就和2000i2一样了。
发表于 2002-4-25 23:32:31 | 只看该作者
https://idesign2002.com/training/cam/GPost/NCJLIBS_P4_Fix.exe
用這個試試!
发表于 2002-4-26 07:04:59 | 只看该作者
   已经下载Java Runtime Environment 1.2.2_008 ,问题解决。
谢谢各位!!!!!
发表于 2003-4-28 20:32:51 | 只看该作者
我装了Java Runtime Environment 1.2.2_011还是出现了这个错误信息
发表于 2003-4-29 05:43:04 | 只看该作者
https://java.sun.com/products/archive/j2se/1.2.2_008/jre/index.html
发表于 2004-1-17 14:28:38 | 只看该作者
怎么会出现这样的问题呢,我一打开就是这样啦,请问各位大哥帮帮忙呢.我是用WIN2000系统的呢,应怎样解决呢,我有图片呢,请和位看看,
GMT+8, 2025-4-30 07:12 , Processed in 0.029961 second(s), 12 queries , Gzip On, Redis On.
