查看: 15492|回复: 4
请教板主??
发表于 2003-5-5 19:43:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
::y
::y小菜想把要PRO/E做的PART 导入到3DMAX中进行 pho_render
用的是IGES格式做的过渡,可太不可思议了,乱七八糟,不成样了。。
能指导一下怎样进行文件的格式转换吗?
   可否来个文件格式讨论的专题,,,caxinfo里这么多的软件,通用的格
式是最好的,怎能么办?
发表于 2003-5-5 19:45:52 | 只看该作者
式是最好的,怎能么办?
 《〈 Datatransform 〉》 一定会是个很好的主题
发表于 2003-5-6 09:40:59 | 只看该作者
以前好象讨论过了,可以先转到rhino里面调整线条,再转3dmax
发表于 2003-5-6 09:51:00 | 只看该作者
试试吧!!
Dear Power Solids / Power Translators downloader,
Power Solids version 1.52 is now available for download.  This new version has several key bug fixes, but it also has a few new features.  Here's a brief list of some of the new features:
1)  Translation of Rhino 3.0 files (import and export)
2)  Extended surface shelling
3)  Blend curve cross section fillet
4)  Alpha Quad meshing - this feature is not completely done, but for those of you that are very excited about this feature, we are giving you an early preview.  We are working on completing this functionality for the upcoming 2.0 release.
Download Power Solids 1.52 from the following link:
https://www.nPowerSoft.com/download/Install_PS_R152.exe
password = spline
nPower Software (https://www.nPowerSoftware.com/)
发表于 2003-5-7 13:17:18 | 只看该作者
paulwave wrote:
::y
  能指导一下怎样进行文件的格式转换吗?
  式是最好的,怎能么办?
建议先用.stp,不行再用IGES
GMT+8, 2025-2-28 12:48 , Processed in 0.021770 second(s), 11 queries , Gzip On, Redis On.
