查看: 17339|回复: 2
【注意】用9.1新POST的朋友<V9.1 Post Processor Information>
发表于 2003-5-5 21:58:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*IMPORTANT* - Version 9.1 update from the CNC Software Post Department
  We have encountered an issue in MasterCAM v9.1 that affects Post Processing.
  Check the setting of the ARCCHECK post flag in ALL post processors to be used with v9.1
  This affects Mill, Router, Lathe, and Wire products.
  Load your post processor (.PST) file into a text editor.
  In Mastercam, select Files, Edit, PST and select the PST file.
  Search for this line >>   arccheck  : 1    #Check for small arcs, convert to linear
  If ARCCHECK exists in the PST file >>
  *** Make SURE that the value setting for ARCCHECK is 1  ***
  Note that this includes these Mill post processors on the v9.1 CD !
  MPFAN.PST
  MPHAAS.PST
  MPAKIRA.PST
  MPAN5300.PST
  MPBOSS5.PST
Post Processing Services
CNC Software Inc.
posts@mastercam.com
发表于 2003-5-6 10:26:21 | 只看该作者
谢谢!
发表于 2010-3-11 11:54:22 | 只看该作者
没看懂什么意思!!!
GMT+8, 2025-4-30 03:47 , Processed in 0.032509 second(s), 12 queries , Gzip On, Redis On.
