查看: 15853|回复: 2
[求助] 螺旋线画法
发表于 2008-1-29 20:43:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
新手,请问在用公式画线的时候
Click Insert > Model Datum > Curve or click the  button on the Datum toolbar.
Click From Equation and Done.
A curve creation dialog box open with the following elements:
Csys—Defines the coordinate system.
Csys Type—Specifies the type of the coordinate system.
Equation—Enters an equation.
Use options in the GET COORD S menu to create or select a coordinate system.
Use options in the SET CSYS TYP menu to specify the type of the coordinate system. The options are: Cartesian, Cylindrical, Spherical
这些坐标的类型和公式怎么输入?
谢谢!
发表于 2008-1-29 22:09:20 | 只看该作者
终于搞定了
终于搞定了
发表于 2008-1-30 09:44:03 | 只看该作者
這樣才好自己搞定..
GMT+8, 2025-4-28 07:11 , Processed in 0.019842 second(s), 11 queries , Gzip On, Redis On.
