查看: 17815|回复: 2
[讨论] 德馬吉DMU-50/70V/50/70,,MASTERCAM,MPGEN5X.PST如何修改?,
发表于 2008-3-11 08:15:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
針對德馬吉DMU-50/70V/50/70 Evolution非正交軸,C轴为TABLE,B轴为YZ轴夹角为45度的雙盤機床,MasterCAM的五軸通用后处理MPGEN5X.PST如何修改?,
发表于 2008-3-11 08:22:12 | 只看该作者
各位大哥: 針對德馬吉DMU-50/70V/50/70 Evolution非正交軸,C轴为TABLE,B轴为YZ轴夹角为45度的雙盤機床,MASTERCAM的五軸通用后处理MPGEN5X.PST如何修改?,是不是修改下面的地方即可?還是另外有設置的地方?編程及建模是不是與標準的雙盤一樣?請指教.
# 5 Axis Rotary Settings
#Assign axis address
str_pri_axis "B"
str_sec_axis "C"
str_dum_axis A"
Machine rotary routine settings
mtype       : 3     #Machine type (Define base and rotation plane below)
                    #0 = Table/Table
                    #1 = Tilt Head/Table
                    #2 = Head/Head
                    #3 = Nutator Table/Table
                    #4 = Nutator Tilt Head/Table
                    #5 = Nutator Head/Head
#Nutating machine (mtype 3-5) describe the plane that the nutated axis
#lays in,  this is the plane perpendicular to the primary axis and
#secondary axis
nut_ang_pri : -45    #Nutating head secondary axis angle from machine Z positive
发表于 2020-5-4 09:59:00 | 只看该作者
好修改,需要的话联系我 robotpost@163.com
GMT+8, 2025-4-12 08:31 , Processed in 0.021775 second(s), 11 queries , Gzip On, Redis On.
