查看: 16491|回复: 1
[求助] ** WARNING 98960 **
发表于 2008-3-29 08:19:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** WARNING 98960 ** The melt temperature calculation does not converge after 200 iterations. Try selecting a more relaxed convergence tolerance or set a higher maximum number of melt temperature iterations in the Advanced options of the Process Settings Wizard.
请问在分析时出现这个警告是什么原因?如何解决?
请高手指点,谢谢!
发表于 2008-3-31 09:29:31 | 只看该作者
依照帮助文件中的提示做就可以了...
** WARNING 98960 ** The melt temperature calculation does not converge after <iteration_count> iterations. Try selecting a more relaxed convergence tolerance or set a higher maximum number of melt temperature iterations in the Advanced options of the Process Settings Wizard.
Explanation: The melt temperature calculation is having difficulty converging.
Cause/Cure: In the Process Settings Wizard, click Advanced options, click Edit next to Solver parameters, and then select the Convergence tab. Select a more relaxed Melt temperature convergence tolerance or set a higher Maximum number of melt temperature iterations and rerun the analysis.
GMT+8, 2025-9-18 10:07 , Processed in 0.040676 second(s), 10 queries , Gzip On, Redis On.
