查看: 16100|回复: 0
[求助] 用vb二次开发sw时,生成零件图时总是弹出错误:“对象变量或with块变量未设置”
发表于 2008-4-29 12:21:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教:
程序如下:
Dim SwApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long
Dim featuredata As Object
Dim feature As Object
Set SwApp = CreateObject("SldWorks.Application")  '引用SOLIDWORKS对象
SwApp.Visible = True    '设置SolidWorks对象为可见
Set Part = SwApp.ActiveDoc   '激活现有文档
Part.SelectByID "Plane1", "PLANE", 0, 0, 0 '激活plane1平面
Part.InsertSketch       '激活草图绘制
Set Part = SwApp.NewDocument("D:\ProgramFiles\SolidWorks\lang\chinese-simplified\Tutorial\part.prtdot", 0, 0#, 0#)
'Solidworks坐标单位为米,故乘以0.001将mm转换为m.
For i = 0 To 15
x(i) = 0.5 * Db * 0.001 * (Sin(u * i / 15) - (u * i / 15) * Cos(u * i / 15))
y(i) = 0.5 * Db * 0.001 * (Cos(u * i / 15) + (u * i / 15) * Sin(u * i / 15))
Next i
For i = 0 To 15
x(i) = x(i) - 0.001 * 0.5 * sb
y(i) = y(i) - 0.001 * (0.5 * Db - Sqr((0.5 * Db) ^ 2 - (0.5 * sb) ^ 2))
Next i
'样条曲线拟合
For i = 0 To 15 Step 1      'y轴左侧齿廓
Part.SketchSpline 15 - i, x(i), y(i), 0
一般调试到Part.SketchSpline 15 - i, x(i), y(i), 0这一句就会出现上述错误。
还有调试的时候能不能从当前位置开始啊?一直从开头开始 运行好慢
GMT+8, 2025-4-29 08:59 , Processed in 0.025358 second(s), 13 queries , Gzip On, Redis On.
