查看: 16125|回复: 7
[分享] GRIP FOR CUBE
发表于 2008-5-6 15:15:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
$$ PROGRAM: CUBE.grs
$$ KEYWORDS:
$$   UTILITY
$$ ABSTRACT:
$$   This routine automatically determines the size of a block
$$   containing the selected solid.
$$   The resulting block is aligned with faces parallel to the
$$   principle planes of the wcs.
$$ SYSTEM TYPE: ALL
$$ THEORY/VARIABLE USAGE:
$$ VERSIONS SUPPORTED: ALL
GRIPSW/DECLRV
NUMBER/AIND,CUBSIZ,DOT1,MAT0(12),RANGE(6),RD(7),RESP,V1(3),V1A(3),V2(3),V3(3)
NUMBER/VZ(3),N
ENTITY/LINES(2),RSRF,SOLID1,S1
$$ DEFINE THE INITIAL DISTANCE FROM THE WCS ORIGIN TO THE RULED SURFACE PLANES,
$$ SET UP ZERO VECTOR:
DATA/CUBSIZ,500
DATA/VZ,0,0,0
$$ ABORT IF NO ACTIVE PART:
IFTHEN/&ACTPRT==1
  MESSG/'ACTIVE PART REQUIRED'
  JUMP/DONE:
ENDIF
$$ GET SOLID OBJECT:
BACK01:
IDENT/'SELECT SOLID OBJECT',SOLID1,RESP
JUMP/DONE:,DONE:,RESP
$$ HIGHLIGHT ENTITY & PROMPT FOR CUBE SIZE:
BACK02:
$$ PARAM/'MAXIMUM CUBE SIZE',$
$$   'MAXIMUM SIZE',INT,CUBSIZ,RESP
$$  JUMP/BACK01:,DONE:,RESP
$$  IFTHEN/CUBSIZ<=0
$$    MESSG/'CUBE SIZE MUST BE POSITIVE NUMBER'
$$    JUMP/BACK02:
$$  ENDIF
$$SOLID1=&ENAME(1,'TEST')
$$ LOOP ONCE FOR EACH AXIS:
DO/DOL90:,AIND,1,3
  $$ SET UP VECTOR POINTING PARALLEL TO AXIS BEING EVALUATED,
  $$ CREATE A RULED SURFACE TO REPRESENT A SIDE OF THE CUBE:
  V3=VZ
  V3(AIND)=1
  IFTHEN/AIND==1
    LINES(1)=LINE/0,-CUBSIZ/2,-CUBSIZ/2,0,CUBSIZ/2,-CUBSIZ/2
    LINES(2)=LINE/0,-CUBSIZ/2,CUBSIZ/2,0,CUBSIZ/2,CUBSIZ/2
  ELSEIF/AIND==2
    LINES(1)=LINE/-CUBSIZ/2,0,-CUBSIZ/2,CUBSIZ/2,0,-CUBSIZ/2
    LINES(2)=LINE/-CUBSIZ/2,0,CUBSIZ/2,CUBSIZ/2,0,CUBSIZ/2
  ELSE
    LINES(1)=LINE/-CUBSIZ/2,-CUBSIZ/2,0,CUBSIZ/2,-CUBSIZ/2,0
    LINES(2)=LINE/-CUBSIZ/2,CUBSIZ/2,0,CUBSIZ/2,CUBSIZ/2,0
  ENDIF
  $$ SHIFT THE LINES OUT TO STARTING POSITION:
  $$ (1/2 THE CUBE SIZE ALONG THE SELECTED AXIS, NEGATIVE)
  MAT0=MATRIX/TRANSL,-SCALVF(CUBSIZ/2,V3)
  TRANSF/MAT0,LINES(1..2),MOVE
  $$ CREATE A RULED SURFACE FOR DISTANCE CHECKING,
  $$ GET THE MINIMUM DISTANCE BETWEEN THE TEST SURFACE & THE SOLID,
  $$ ERROR ON ZERO DISTANCE VALUES:
  RSRF=RLDSRF/LINES(1),,LINES(2)
  RD=RELDST/RSRF,SOLID1
  IF/RD(7)==0,JUMP/CROSSB:
  $$ CALCULATE VECTOR BASED ON SHORTEST LINE BETWEEN THE TWO OBJECTS:
  $$ (CHECK THE VECTOR AGAINST A REFERENCE VECTOR TO MAKE SURE
  $$ THE SHAPE FITS INSIDE THE CUBE
  V1(1)=RD(4)-RD(1)
  V1(2)=RD(5)-RD(2)
  V1(3)=RD(6)-RD(3)
  DOT1=DOTF(UNITF(V3),UNITF(V1))
  IF/DOT1==-1,JUMP/OUTSID:
  IF/ABSF(DOT1)<1,JUMP/BADDOT:
  $$ GET THE ORDINATE VALUE FROM THE END OF THE LINE THAT TOUCHES THE
  $$ SOLID BODY:
  RANGE(AIND*2-1)=RD(AIND+3)
  PRINT/'FACE '+ISTR(AIND*2-1)+' OF 6 EVALUATED'
  $$ NOW SHIFT THIS RULED SURFACE TO THE OTHER SIDE OF THE OBJECT AND
  $$ REPEAT THE PROCESS:
  V2=SCALVF(CUBSIZ,UNITF(V3))
  MAT0=MATRIX/TRANSL,V2
  V1A(1)=RD(4)-RD(1)
  V1A(2)=RD(5)-RD(2)
  V1A(3)=RD(6)-RD(3)
  DOT1=DOTF(UNITF(V3),UNITF(V1A))
  IF/DOT1==1,JUMP/OUTSID:
  RANGE(AIND*2)=RD(AIND+3)
  PRINT/'FACE '+ISTR(AIND*2)+' OF 6 EVALUATED'
  $$ CLEAN UP:
DELETE/RSRF
DELETE/LINES(1..2)
DOL90:
$$ DISPLAY SIZE & CREATE BLOCK ENCLOSING THE SOLID:
PRINT/USING,'BLOCK SIZE:   #@@@.@@@@@ x #@@@.@@@@@ x #@@@.@@@@@',$
  RANGE(2)-RANGE(1),RANGE(4)-RANGE(3),RANGE(6)-RANGE(5)
S1=SOLBLK/ORIGIN,RANGE(1),RANGE(3),RANGE(5),$
  SIZE,RANGE(2)-RANGE(1),RANGE(4)-RANGE(3),RANGE(6)-RANGE(5)
&COLOR(S1)=&GRAY
JUMP/DONE:
CROSSB:
  MESSG/'SOLID CROSSES CUBE BOUNDARY'
  JUMP/REDO:
OUTSID:
  MESSG/'SOLID OUTSIDE CUBE BOUNDARY'
  JUMP/REDO:
BADDOT:
  MESSG/'DISTANCE VECT NOT PARALLEL TO AXIS!'
  JUMP/REDO:
REDO:
DELETE/RSRF
  DELETE/LINES(1..2)
  MESSG/'INCREASE CUBE SIDE TO TRY AGAIN'
  JUMP/BACK02:
DONE:
HALT
发表于 2008-5-6 16:01:45 | 只看该作者
GRX FILE FOR CUBE
GRX FOR CUBE
发表于 2008-5-12 09:01:39 | 只看该作者
用这个测试下,不要动坐标系和实体,直接试下
发表于 2008-5-22 18:34:05 | 只看该作者
看不动,帖个图
发表于 2008-6-2 21:22:02 | 只看该作者
更改以下就可以
BACK02:
  IFTHEN/CUBSIZ<=0
    JUMP/BACK02:
  ENDIF
发表于 2008-6-2 21:25:44 | 只看该作者
更新
发表于 2008-9-18 13:18:47 | 只看该作者
看不懂!!!!!!!!!!!!
发表于 2010-8-13 22:20:03 | 只看该作者
支持一下啊。
GMT+8, 2025-2-7 18:59 , Processed in 0.028781 second(s), 10 queries , Gzip On, Redis On.
