查看: 16772|回复: 4
【求助】一些很菜的问题
发表于 2002-4-30 15:22:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问各位高手,CATIA里有没象PROE里的查询选取,要选上内部的图元还挺麻烦的,还有CATIA的旋转放大缩小好象很麻烦,有没有好点的办法?小试草绘感觉还可以,有的地方比PROE要好,谢谢各位啦。
发表于 2002-4-30 15:52:07 | 只看该作者
也可象PRO/E类似的按住CTRL键,再按MOUSE的中键(或先中键后CTRL),实现缩放,旋转,当然只按MOUSE也行,按中键不放,移动MOUSE是平移,再加按左键是旋转,点右键是缩放。
这样很麻烦吗?呵呵
发表于 2002-4-30 17:11:51 | 只看该作者
wrucun wrote:
请问各位高手,CATIA里有没象PROE里的查询选取,要选上内部的图元还挺麻烦的,...
Method 1
  1. Click anywhere in the geometry area.
2. Position your pointer over the object you want to select.
3. Press any keyboard arrow.
The preselection navigator appears.
Method 2
1. Select the Tools->Options... command. In the General category, select the Display sub-category then the Navigation tab.
2. Check the option "Display the preselection navigator after ... seconds", set the spinner to the time delay, and click OK.
The spinner sets the amount of time, in seconds, which elapses before the preselection navigator appears after pointing at an object.
  3. Click anywhere in the geometry area using the middle mouse button, dragging slightly the cursor.
4. Point to the part of the object you want to select.
   5. Press any keyboard arrow.
The selection tool is displayed after the time delay you set:
发表于 2002-4-30 17:21:19 | 只看该作者
8D
发表于 2002-4-30 18:02:06 | 只看该作者
大家答得这么完整,连插嘴的分也没有呀!:)
GMT+8, 2025-4-12 12:16 , Processed in 0.021627 second(s), 13 queries , Gzip On, Redis On.
