查看: 17118|回复: 1
[求助] UF_MODL_intersect_objects
发表于 2008-5-19 10:22:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是ug中的一个例子,两条直线、一段圆弧分别和一个面相交。其中一条直线和面相交得一个点。如果给定一个方向,在这个点处做一个向量,我如何引用这个啊!我刚接触不久,希望高手指教!
#include <stdio.h>
#include <uf_modl.h>
#include <uf.h>
#include <uf_obj.h>
#include <uf_curve.h>
#include <uf_defs.h>
#include <uf_csys.h>
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
static void get_intersect(tag_t curve, tag_t face, double tol);
static int report( char *file, int line, char *call, int irc)
  if (irc)
     char    messg[133];
     printf("%s, line %d:  %s\n", file, line, call);
     (UF_get_fail_message(irc, messg)) ?
       printf("    returned a %d\n", irc) :
       printf("    returned error %d:  %s\n", irc, messg);
  return(irc);
static void do_ugopen_api(void)
  tag_t base_sheet_id, line_id;
  tag_t face, arc_tag, line2_id;
  int num_pole_u = 4;
  int num_pole_v = 4;
  int u_ord = 4;
  int v_ord = 4;
  int knot_fix;
  int pole_fix;
  int i, j, k = 0;
  UF_CURVE_line_t line_coords  = {1.5,1.5,-2,1.5,1.5,1.0};
  UF_CURVE_line_t line_coords2 = {0.0, 3.0, 0.0};
  UF_CURVE_arc_t arc_coords = {NULL_TAG,0.0,180*DEGRA,1.5,0.0,-1.5,0.25};
  uf_list_p_t list;
  double weight = 1.0;
  double u_knot[9] = {0.0,0.0,0.0,0.0,1.0,1.0,1.0,1.0,1.0};
  double v_knot[9] = {0.0,0.0,0.0,0.0,1.0,1.0,1.0,1.0,1.0};
  double pole[64];
  double tol = .001;
  double matrix_values[9] = {1.0, 0.0, 0.0,
                             0.0, 0.0, 1.0,
                             0.0, 1.0, 0.0};
  /* Create pole array data. */
  for (i = 0; i < 4; i++) {
    for (j = 0; j < 4; j++) {
      pole[k++] = i;
      pole[k++] = j;
      pole[k++] = 0.0;
      pole[k++] = weight;
  /* Create base surface. */
  UF_CALL(UF_MODL_create_bsurf(num_pole_u, num_pole_v, u_ord, v_ord,
                               u_knot, v_knot,pole,&base_sheet_id,
                               &knot_fix,&pole_fix));
  /* Get faces. */
  UF_CALL(UF_MODL_ask_body_faces(base_sheet_id,&list));
  UF_CALL(UF_MODL_ask_list_item(list,0,&face));
  UF_CALL(UF_MODL_delete_list(&list));
  /* Create line. */
  UF_CALL(UF_CURVE_create_line(&line_coords,&line_id));
  /* Get line intersection. */
  get_intersect(line_id, face, tol);
  /* Create coincident line. */
  UF_CALL(UF_CURVE_create_line(&line_coords2,&line2_id));
  UF_CALL(UF_OBJ_set_color(line2_id, UF_OBJ_YELLOW));
  /* Get coincident line intersection data */
  get_intersect(line2_id, face, tol);
  /* Create arc. */
  UF_CALL(UF_CSYS_create_matrix(matrix_values,&arc_coords.matrix_tag));
  UF_CALL(UF_CURVE_create_arc(&arc_coords, &arc_tag));
  /* Get arc intersection. */
  get_intersect(arc_tag, face, tol);
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int param_len)
  if (!UF_CALL(UF_initialize()))
    do_ugopen_api();
    UF_CALL(UF_terminate());
int ufusr_ask_unload(void)
  return (UF_UNLOAD_IMMEDIATELY);
  int num_intersects, type, i;
  UF_MODL_intersect_info_p_t *intersect_data;
  UF_CALL(UF_MODL_intersect_objects(curve,face,tol,&num_intersects,&intersect_data));
  printf("\n Number of intersections = %d\n", num_intersects);
  for(i = 0; i < num_intersects; i++)
    type = (intersect_data)->intersect_type;
    switch(type)
      case UF_MODL_INTERSECT_POINT:
        printf("\nx,y,z coordinates are: (%f, %f, %f)\n",
               (intersect_data)->intersect.point.coords[0],
               (intersect_data)->intersect.point.coords[1],
               (intersect_data)->intersect.point.coords[2]);
        printf("Object 1 UV parameters are: (%f, %f)\n",
               (intersect_data)->intersect.point.object_1_u_parm,
               (intersect_data)->intersect.point.object_1_v_parm);
        printf("Object 2 UV parameters are: (%f, %f)\n",
               (intersect_data)->intersect.point.object_2_u_parm,
               (intersect_data)->intersect.point.object_2_v_parm);
        break;
      case UF_MODL_INTERSECT_COINCIDE:
        printf("\nCoincident curve tag is: %d\n",
               intersect_data->intersect.coincide.identifier);
               intersect_data->intersect.coincide.object_1_first_parm,
               intersect_data->intersect.coincide.object_1_second_parm);
               intersect_data->intersect.coincide.object_2_first_parm,
               intersect_data->intersect.coincide.object_2_second_parm);
        break;
      case UF_MODL_INTERSECT_CURVE:
        printf("\nThe curve identifier is: %d\n",
               (intersect_data)->intersect.curve.identifier);
        break;
      default:
        printf("\nSomething went wrong, we shouldn't be here!");
        break;
    /* Free each element of the array. */
      UF_free(intersect_data);
  if(num_intersects != 0)
    /* Free the array. */
发表于 2008-5-20 10:40:37 | 只看该作者
谢谢分享......
GMT+8, 2025-3-6 02:06 , Processed in 0.030041 second(s), 10 queries , Gzip On, Redis On.
