查看: 16846|回复: 0
CAA问题:对投影圆标注它与直线间的距离
发表于 2008-5-20 15:51:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问题是这样:
我想创建3D投影元素(圆和直线)之间的距离,这个尺寸线应该是从圆心到直线的距离,但是他却创建的是圆的边界与直线的距离;
同样的程序,对2D手画的圆和直线,就可以标出圆心到直线的距离。
我想标出3D投影元素(圆和直线)之间的从圆心到直线的距离,但是不能先画出圆心再标,就是说不能再创建新的元素!(这个问题也问过Dassault,他们也解决不了,很有挑战啊!呵呵)
请各位指点一下! 多谢!
其实我觉得开关就是dimDef._Info = ifCenter;这句,但是不知为什么,他对3D投影圆不管用,对2D手画的圆就OK!
程序如下:
CreateDim(IUnknown_var  _circle,IUnknown_var  _line)
        // Gets the view annotation factory
        CATIDrwAnnotationFactory_var spAnnFactory = _pView;
        // Vertical distance dimension creation between Circle and Line
        CATDrwDimType dimType = DrwDimDistance;
        CATDimDefinition dimDef;
        CATIUnknownList * piSelectionsList =NULL;
        CATIUnknownListImpl * piListsel = new CATIUnknownListImpl();
        piListsel->QueryInterface(IID_CATIUnknownList, (void **) &piSelectionsList);
        piListsel->Release(); piListsel=NULL;
        if (piSelectionsList)
                piSelectionsList->Add(0, _circle);
                piSelectionsList->Add(1, _line);
        double pts[2][2];
        dimDef.Orientation = DrwDimAuto ;
        if(SUCCEEDED( spAnnFactory->CreateDimension(piSelectionsList,(double**)pts,dimType,&dimDef,&_piDim) ) )
                piSelectionsList->Release();
                piSelectionsList = NULL;
                return true;
        else
                if (piSelectionsList) {piSelectionsList->Release(); piSelectionsList = NULL;}
                return false;
GMT+8, 2025-4-21 04:30 , Processed in 0.020924 second(s), 12 queries , Gzip On, Redis On.
