查看: 20938|回复: 8
[转贴] 給您十個選擇CoCreate2008的好理由
发表于 2008-6-6 09:57:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
給您十個選擇CoCreate 2008的好理由 CoCreate 2008 是 PTC參數科技公司最新一代的3D CAD, PDM 及協同商務等具備多項功能的設計軟體 (Explicit Modeling)。針對產品生命週期短或有快速完成產品設計需求的公司 CoCreate 2008 提供了多項有效節省設計時程的功能,現在馬上提供給您十個好理由選擇使用 CoCreate 2008。
CoCreate 2008 is the latest release of PTC’s explicit CAD, PDM & collaboration software. CoCreate 2008 features new, timesaving tools and options specifically designed for companies combating short design cycles and pressures to create one-off product designs quickly. Here are just the top 10 reasons why you’ll want to buy CoCreate 2008 right now:
1.新一代的特徵陣列功能 (Revised pattern capabilities)有了全新強化的導引預覽功能,讓您可以更快速建立特徵陣列、重新定義以及重複利用您自行定義的特徵。不論是口袋造型或凹槽造型的特徵都可以自行定義完成陣列,其功能的強化以遠超過原本的機械加工(Machining)特徵功能。在您進行特徵陣列設計時,您可以在利用全新的導引預覽功能抑制部分特徵。此外,您更可以隨心所欲的更改任一特徵,並將其改變套用至其他相關的特徵上。〔詳細功能說明
With the new and improved user guidance, you can create patterns faster, modify them later, and reuse your user-defined features such as pockets and slots – far beyond the predefined machining features already included in CoCreate Modeling. After you create your patterns, you can use the brand new capabilities inside linear, grid, array, and irregular patterns to selectively suppress features. Plus, you can automatically propagate feature changes to any pattern across a part to avoid redundant design effort.
2.依據可加工性強化鈑金設計功能 (Enhanced Sheet Metal Design for Manufacturability)現在當您的 CoCreate 鈑金資料庫更新後,您可以使用新的分析及調整設計功能立即更新刀具及鈑材厚度等相關資料,讓您的新設計可立即回饋到您的實際加工設備、配合廠商及材料資源等。讓設計工作與實際加工同步進行,您將可以節省不必要的刀具費用及施工延遲的浪費。新的色碼辨識功能提供您顯著的回饋,使您可更快更新下料及沖孔動作與新刀具的配合;或使用替代的鈑材修正折彎及離隙讓角等。同時,CoCreate鈑金模組可處理匯入不同厚度的鈑金零件,因此您將可毫無阻礙地直接修改由其他CAD系統所建立的設計資料。〔詳細功能說明
Now when your CoCreate Sheet Metal library changes, you can use the new Analyze and Redesign command to instantly update tooling and material thickness across product designs in response to changes in machinery, suppliers and material availability. You’ll avoid unnecessary tooling costs and manufacturing delays by keeping sheet metal product designs and manufacturing processes in sync. Color-coded results give strong visual feedback to help you update stamps and punches to match the new tooling, or adjust bend and corner reliefs for substituted material. Also, CoCreate Sheet Metal now handles imported variable-thickness sheet metal parts so nothing will stop you from modifying design data from other CAD systems.
3.儲存您的工作進度 (Save your work-in-progress)我們已經強化整合設計工具(CoCreate Modeling) 及資料庫管理系統 (Model Manager) ,因此即使在您的工作中包含多個被鎖定的零組件或版本,您仍可以快速儲存您的日常工作進度。您可以載入多個零組件的版本並修改已解除鎖定的幾何或組件結構,並在無須多於的動作下,將您的變更快速回存到資料庫中。您可自由地評估儲存物件版本或直接儲存工作進度。〔更多關於Model Manager的新增功能
We’ve further enhanced the integration between CoCreate Modeling and CoCreate Model Manager so you can save your daily work even when you have multiple revisions of locked parts and assemblies loaded into your working session. You can load multiple revisions of an assembly or model, modify the unlocked geometry or assembly structure, and save your changes to the database without extra work of removing the locked, revisioned items. Feel free to evaluate “what if” scenarios between part revisions and still save your work-in-progress before you go to lunch!
4.新的彩現視圖功能 (New shaded and rendered drawing views)在工程圖視圖表現的功能裡多了全新彩現及照片擬真表現等選項,可讓您的視圖表現更加真實美觀。這項功能並非固定貼圖,而是與3D資料向互關聯的彩現表示,且可與3D資料同步更新。有了這些更真實的視圖表示,讓您可以更輕鬆的介紹您的產品並提升與客戶溝通的品質,減少溝通問題。〔詳細功能說明
Watch your drawings come alive with the new shaded and photo-realistic rendering options for drawing views. Unlike a static image, these lifelike views are associative to the 3D product design so they’ll keep in sync with any changes to the associated model. Because these realistic drawings are easier to interpret, you can improve the quality of communication and avoid costly misunderstandings.
5.強化任務管理功能 (Enhanced CoCreate Task Agent)Cocreate 任務管理(Task Agent)功能為CoCreate Model Manager與CoCreate Drawing Manager的附加模組功能。提供您更多自動撤換服務來減少您在工程圖及零組件上的重覆運算動作。例如,您可以建立一個例行工作,自動與另一個事件觸發基礎的系統進行資料交換。CoCreate任務管理功能也包含組態設定強化,例如在零組件狀態變更時,進行過濾或分類列印工作、更新干涉分析等等。〔詳細功能說明
CoCreate Task Agent, a CoCreate Model Manager and CoCreate Drawing Manager add-on module, now offers you even more automatic back-end services to eliminate repetitive and time-consuming operations on your drawings and models. For instance, you can now create general jobs, such as an automatic data exchange with another system based on an event trigger. CoCreate Task Agent also includes configuration enhancements, such as the configurable filtering and sorting of plot jobs or updating clash analysis jobs automatically based on part or assembly state transitions.
6.曲面編輯:擷取曲面參數 (Surface Editing: Capture Surface Properties)當您使用CoCreate Surfacing 曲面模組建立一個網格曲面時,您可以將曲面的條件及參考線儲存在曲面零件內。當您稍後要進行編輯時,您可以直接使用這些原來的邊界條件及參數快速編輯修改這個曲面。系統提供即時且自由的操作方式,讓您可以更快速編輯曲面並開發出更多更好的產品。〔詳細功能說明
When you create skin surfaces in CoCreate Surfacing, you can store the properties for the 3D curve mesh and surface conditions defining the skin as part of the model. When you later modify the skin surface, you can use these original boundary conditions and make changes to the surface faster and easier than you thought possible. And, with on-the-fly freeform manipulation or persistent surface properties, you can explore different skin shapes and style options, edit surfaces faster, and release a better product to market.
7.曲面編輯:定義曲面屬性 (Surface Editing: Assign Surface Properties)在CoCreate 2008,您可以分析匯入的或自行產生的網格曲面來自動產生3D架構線,並可將其儲存為該曲面的屬性資料。之後更可直接利用這些以儲存的屬性資料來驅動編輯成新的曲面。如此一來,設計者可用最少的時間重新建立匯入的3D設計資料,並且有更多的時間來進行設計。而貴公司在設計流程中也可更輕易地處理不同的CAD設計資料,增加在市場上的競爭力。〔詳細功能說明
With CoCreate Modeling 2008, you can analyze both imported and native skin surfaces to automatically create 3D curve meshes that you can store as surface properties. You can later use these stored surface properties to drive subsequent modifications to new skins. The result: designers spend less time recreating imported 3D design data and more time using it, and companies can better leverage multi-source CAD data in the design process.
8.曲面編輯:線架構編輯 (Surface Editing: Wire Editor)全新的線架構編輯功能將帶來更大的彈性進行空間曲線的修改。線架構編輯功能可自動偵測並保存原有相切條件,其會自動偵測不同曲線條件,例如平面曲線、固定半徑圓或圓弧、固定軸線的弧或圓柱、及固定頂點等等,亦可在空間曲線上插入新的邊界條件。此外,您可以更快編輯曲面網格線,並且在空間中使用單一功能進行分割、合併及修改等多項編輯運算。〔詳細功能說明
The new Wire Editor delivers greater flexibility for making changes to 3D curves, while automatically detecting and protecting established tangency conditions. Because Wire Editor also automatically detects different curve conditions, such as curve in plane, fixed radius for arcs and circles, fixed axis for arcs and cylinders, and fixed vertex, you can insert new conditions onto 3D curves. Plus, you can more quickly modify meshes for surfacing and adjust routing of complicated paths through 3D space with a single tool and multiple options for splitting, merging and modifying curves.
9.快速剖切與修改 (Fast cross sectional modification)在CoCreate 2007版新增的剖切功能,在CoCreate 2008更新增了多項功能來增強對於旋轉幾何物件的剖面設計。這些新功能可減少針對旋轉幾何物件許多重複的定義步驟,而只需要簡單的動作就可以完成,如此一來您可以更快地設計出更好的產品。〔更多其他新增功能
CoCreate 2007 redefined designing in cross-section. CoCreate Modeling 2008 builds on that foundation and adds new capabilities to improve the cross-sectional design of components with rotational geometry, such as spindles. These new capabilities dramatically reduce the number of repetitive steps used to modify components with rotational geometry, often down to a single operation, so you’ll work faster and more productively.
10.智慧圓角功能 (Intelligent Blend)新的進階圓角功能,一致化的圓角對話框選項以及內建的智慧辨識功能讓您可以更輕易完成複雜圓角設計,增加您每天的產能。我們將建立圓角與插入圓角整合為一新的指令,讓系統自動辨識圓角造型,系統首先提供給您是一般期望的圓角造型,或者您可以自行調整對話框內圓角選項來達到您預期的圓角造型設計。〔詳細功能說明
New blend improvements, streamlined blend options, and built-in intelligence take the complexity out of complex blending operations, increasing your everyday productivity. We’ve merged blend creation and blend insertion into a single command that automatically interprets the blend scenario and first offers you the commonly expected blend result. Or, you can achieve different results with the various options that control the shape of blends where they intersect other faces.
原文網址:https://www.ptc.com/appserver/wcms/standards/free.jsp?im_dbkey=69679&icg_dbkey=841
若您有任何疑問,也可參考官方網站取得夠多資訊: www.ptc.com | www.cocreate2008.com
发表于 2008-6-8 16:47:52 | 只看该作者
恩,很好的介绍资料,一起学习
发表于 2008-6-10 16:37:17 | 只看该作者
灌水
灌水
灌水
灌灌灌水
[ 本帖最后由 goodmanplus 于 2008-6-10 16:38 编辑 ]
发表于 2008-6-29 11:56:55 | 只看该作者
感觉和PROE差不多啊。
发表于 2008-7-18 07:38:58 | 只看该作者
YZY539,我知道你是无所不能的,2007装上去用不了,可不可以帮一下
发邮件:boll1979@163.com
发表于 2008-8-4 17:09:26 | 只看该作者
安装问题已经搞定了
发表于 2008-8-4 19:41:32 | 只看该作者
不好意思,前段时间都在出差,最近才看见你的留言.
发表于 2008-8-5 13:09:28 | 只看该作者
支持~顶一个
[ 本帖最后由 25years 于 2008-8-5 13:13 编辑 ]
发表于 2008-8-5 13:18:25 | 只看该作者
踩场踩场拉~有没有要去深圳发布会的呀?
大家约到一起过去吧`
QQ:1029594624
GMT+8, 2025-2-24 09:31 , Processed in 0.032958 second(s), 12 queries , Gzip On, Redis On.
