查看: 16442|回复: 2
[求助] 版主看看,这是在继续正常运行吗?
发表于 2008-6-6 16:55:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** WARNING 702280 ** Circuit has more than one outlet node. Using
                     node   25915
** WARNING 701360 ** Beam element   51205  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   51206  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   51207  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   51208  has a very bad length/diameter ratio
** WARNING 701380 ** Warnings were reported in the model
** WARNING 700530 ** Problem encountered in circuit with inlet node   25938 .
                     The continuity equation has not converged.
                     Convergence residual = 1.95212E-05
| Inlet   |Flowrate     |    Reynolds No.       |Press. drop   | Pumping     |
| node    |in/out       |       range           |   over       | power over  |
|         |             |                       |  circuit     |  circuit    |
|         |  (lit/min)  |                       |    (MPa)     |    (kW)     |
|  25938  |     0.82    |  10000.0  -  24876.1  |      0.0065  |   8.802e-05 |
|  25890  |     0.82    |  10000.0  -  10000.0  |      0.0009  |   1.280e-05 |
Now beginning the task: Boundary Integration
Current time is:  Fri Jun 06 11:07:45 2008
** WARNING 700940 ** Two elements are too close
                   Check element    5303  in the Part_model and element   48775  in the Part_model
                   Check element    7010  in the Part_model and element    7026  in the Part_model
                   Check element    7424  in the Part_model and element    7586  in the Part_model
                   Check element   10239  in the Part_model and element   10238  in the Part_model
                   Check element   10543  in the Part_model and element   50392  in the Part_model
                   Check element   47566  in the Part_model and element   47568  in the Part_model
                   Check element   48184  in the Part_model and element   10472  in the Part_model
                   Check element   48625  in the Part_model and element   48630  in the Part_model
                   Check element   44653  in the Part_model and element    6198  in the Part_model
                   Check element   47420  in the Part_model and element    5431  in the Part_model
                   Check element    5652  in the Part_model and element   44655  in the Part_model
                   Check element   47036  in the Part_model and element   47027  in the Part_model
                   Check element   48587  in the Part_model and element   48588  in the Part_model
Now beginning the task: Solution of equilibrium TMP field
Current time is:  Fri Jun 06 11:12:35 2008
|External  |Cycle time|Avg temp  |Avg temp  |Dif temp  |Dif temp  |Circ temp |
|iteration |   (s)    |iteration |deviation |iteration |deviation |residual  |
|        1 |   20.000 |       11 |30.000000 |        0 | 0.000000 | 1.000000 |
|        1 |   20.000 |        8 |30.000000 |        0 | 0.000000 | 1.000000 |
上面出了那么多问题,好像还在运行,那继续运行对分析结果有啥影响吗?
发表于 2008-6-6 23:27:57 | 只看该作者
是在运行,如果系统默认选的出水点与你的设计不符那分析结果误差就大了。其余的没什么大的影响。
发表于 2008-6-7 11:31:44 | 只看该作者
我第一次做水路,照着图纸画的,我也不知道网格怎么不合理啦,我只会用BEAM做,MESH TOOL 重新划分网格,自己在摸索,出水点前后模各一个,系统还会默认再选择吗?请高手指教,我的邮箱是DAIFY@KURODA-SZ.COM
GMT+8, 2025-2-21 03:05 , Processed in 0.024766 second(s), 11 queries , Gzip On, Redis On.
