查看: 17326|回复: 2
【求助】怎样解释曲面的U、V方向?????
发表于 2002-5-1 18:53:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在Pro/E中mesh曲面时以U、V方向来mesh,究竟哪是它们的方向??
发表于 2002-5-2 22:31:40 | 只看该作者
我认为没有必要研究这个,它只是代表可自由修改此曲面的Uv方位,用来便于选择的。
发表于 2002-5-6 09:52:36 | 只看该作者
U, V are the special for the discription of a parametric surface. 0<=U,V<=1. So, any surface can be formulated by two parameters U and V. If you want to know more about U, V, you can refer to some materials of parametric surface. After that, you will understand.
But, as a application engineer, what you need to know is to how to use them. I think that's enough.
Good luck.
GMT+8, 2025-4-27 02:56 , Processed in 0.022922 second(s), 12 queries , Gzip On, Redis On.
