查看: 17066|回复: 4
[求助] ugapi在面上偏置的问题~~
发表于 2008-6-12 10:03:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序实现的功能是:鼠标选取一个面的边线,然后在面上偏移一个距离~
调试的时候总是内存冲突~
用到的函数
UF_CURVE_create_ocf_feature(&offset_data,feature);
哪位大哥大姐帮我看看吧~!
程序代码如下:
#include "StdAfx.h"
#include "Main.h"
#include <math.h>
#include <windows.h>
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
static int init_proc3(UF_UI_selection_p_t select,void* user_data)
    int num_triples=1;
UF_UI_mask_t mask[] = //{{UF_solid_type,UF_solid_face_subtype,UF_UI_SEL_FEATURE_ANY_FACE},
//{UF_solid_type,0,UF_UI_SEL_FEATURE_BODY}};
{UF_solid_type,0,UF_UI_SEL_FEATURE_ANY_EDGE};
//{ UF_spline_type, 0, 0 };
    if((UF_UI_set_sel_mask(select,
            UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,
            num_triples, mask))== 0)
        return (UF_UI_SEL_SUCCESS);
    else
        return (UF_UI_SEL_FAILURE);
UF_MB_cb_status_t Application1(
UF_MB_widget_t widget,
UF_MB_data_t client_data,
UF_MB_activated_button_p_t button)
{   if(UF_initialize()!=0)
  return(UF_MB_CB_CONTINUE);
    char cue[] = "偏移边线";
    char title[] = "选择边线";
    int response;
    tag_t edge,view;
    tag_t face=NULL_TAG;
    double cursor[3];
    if((UF_UI_select_with_single_dialog(cue,title,
                   UF_UI_SEL_SCOPE_NO_CHANGE, init_proc3, NULL,
                   &response, &edge, cursor, &view))!=0)
         if (response == UF_UI_OBJECT_SELECTED ||
            response == UF_UI_OBJECT_SELECTED_BY_NAME)
            printf("object tag = %d\n", edge);
            if (response == UF_UI_OBJECT_SELECTED)
                printf("view = %d\n", view);
                printf("cursor position = %f %f %f\n",
                        cursor[0], cursor[1], cursor[2]);
        /* unhighlight selected object */
        UF_DISP_set_highlight(edge,1);
    uf_list_p_t face_list;
     UF_MODL_create_list(&face_list);
     UF_MODL_ask_edge_faces(edge,&face_list);
  UF_MODL_ask_list_item(face_list, 0, &face);
  UF_MODL_delete_list(&face_list);
     UF_CURVE_ocf_data_t  offset_data;
     tag_t* feature;
    UF_CURVE_ocf_string_data_t  string_data;
  string_data.string_tag = edge;
  string_data.offset_direction = 1;
  string_data.num_offsets = 1;
  string_data.offset_distances=new UF_CURVE_ocf_values_t;
  strcpy(string_data.offset_distances->string,"5.0000");
  offset_data.face_data=new UF_CURVE_ocf_face_data_t;
  offset_data.face_data->face_tag = face;
  offset_data.string_data=new UF_CURVE_ocf_string_data_t;
  offset_data.string_data = &string_data;
  offset_data.num_string_data = 1;
  offset_data.cross_boundary_mode = UF_CURVE_OCF_CROSS_BOUNDARIES;
  offset_data.offset_method = UF_CURVE_OCF_CHORDAL;
  offset_data.trim_method =UF_CURVE_OCF_TANGENT;
  offset_data.span_method = UF_CURVE_OCF_SPAN_NONE;
  offset_data.dist_tol = 0.025;
  offset_data.ang_tol = 0.5;
  offset_data.string_tol = 0.025;
     int irc=UF_CURVE_create_ocf_feature(&offset_data,feature);
   TRACE("%d",irc);
  char    messg[133];
  UF_get_fail_message(irc,messg);
   UF_terminate();
发表于 2008-6-12 11:31:25 | 只看该作者
tag_t  feature;
int irc=UF_CURVE_create_ocf_feature(&offset_data,&feature);
发表于 2008-6-12 15:07:57 | 只看该作者
回复 2楼 supergirl 的帖子
这样我也试了,也不行~~还是内存冲突~~
发表于 2008-6-13 09:28:37 | 只看该作者
内存冲突这种说法我倒是第一次听说,而且你这段程序,也不至于造成所谓的内存冲突吧。
你调试一下,看程序是死在哪一句上,这样比较好确定一下问题。
但是上面我说的那个,你的那种用法是肯定会导致内存问题的。
发表于 2008-6-13 09:35:56 | 只看该作者
回复 4楼 supergirl 的帖子
UG/API中的face collector是什么?怎么把face tag 转换为face collector tag呢?
GMT+8, 2025-10-18 18:34 , Processed in 0.036606 second(s), 12 queries , Gzip On, Redis On.
