查看: 15986|回复: 0
[讨论] 以下错误怎么修改,不改会影响什么结果?
发表于 2008-7-18 08:11:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Analysis model: residual strain.
** WARNING 1714020 ** The CRYSTALLINITY term in the PARALLEL strain model had
                      values which were too HIGH in  75.0 % of part elements
                      (volume fraction). The upper limit has been used for
                      these elements.
** WARNING 1714060 ** The ORIENTATION term in the PARALLEL strain model had
                      values which were too HIGH in  96.0 % of part elements
                      these elements.
** WARNING 1714030 ** The CRYSTALLINITY term in the PERPENDICULAR strain
                      model had values which were too HIGH in  75.0 % of
                      part elements (volume fraction). The upper limit has
                      been used for these elements.
** WARNING 1714070 ** The ORIENTATION term in the PERPENDICULAR strain model
                      had values which were too HIGH in  59.7 % of part
                      elements (volume fraction). The upper limit has been
** WARNING 1714140 ** The MOLD RESTRAINT term in the PARALLEL strain model
                      had values which were too LOW in 100.0 % of part
                      elements (volume fraction). The lower limit has been
** WARNING 1714150 ** The MOLD RESTRAINT term in the PERPENDICULAR strain
                      model had values which were too LOW in 100.0 % of part
For the parallel shrinkage model, the relative distance to the centroid of
                                    experimental measurements is 42.927 .
For the perpendicular shrinkage model, the relative distance to the centroid of
                                    experimental measurements is 40.774 .
GMT+8, 2025-4-23 03:26 , Processed in 0.050103 second(s), 11 queries , Gzip On, Redis On.
