查看: 44010|回复: 57
[原创] DME伸缩芯 collapsible core
发表于 2008-7-26 22:16:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
脱螺纹机构,方便成型,模具结构简单,节省成型时间1/3以上。
Collapsible core demoulding technology is one of key technologies in moulds injection and extrusion, it applies for parts that inner cavity dimension is bigger than outer dimension, it could demould quickly and successfully when injection and extrusion, such as pipe / fittings with collapsible, instrument shell, sealed gate. etc.
Technology characteristic:
1、Ingenious structure, moving and demoulding in limited space
2、High precision and consistency for components
3、Cool machining technology for material with high hardness
4、Security design: avoid damage moulds cavities and components when working
24 Cavity Collapsible Core Mold
Having a straight pin improved stability of the collapsible core segments improving the dimensional accuracy of the molded part. The pin diameter matches the inside diameter of the segments and by being contained by a stripper or containment ring matched to the outside of the segments the pin and the segmented sleeves are self centering and extremely accurate.
Shorter and spring loaded segments reduces the possibility of injection pressure opening the segments. This reduces the time for injection and reduces cycle time. The increased contact area between the pin and the collapsible core segments improves mold cooling allowing for faster cycle times. The change of shape of the contact area between the segments and the pin, rounded surfaces moving across flat surfaces, reduces wear allowing for less maintenance.
需要提供帮助,请联系我,DME 佘永侃 QQ:45837332 E-MAIL:yongkan2001@sina.com 手机:13918218772
发表于 2008-7-26 22:17:56 | 只看该作者
DME伸缩芯型号
发表于 2008-7-26 22:22:08 | 只看该作者
DME MINI collapsible core
发表于 2008-7-27 11:43:40 | 只看该作者
兄弟:图片中看不是很清楚,能否发个3D 过来看一下 或实物也行!
早就听说有此东东,但不是很了解此东东!
发表于 2008-7-27 13:10:10 | 只看该作者
早就听说有此东东,但不是很了解此东东!
强烈要求有3D图,好让咋们早日用上这东东。强烈!
发表于 2008-7-27 15:11:12 | 只看该作者
3D没有办法传上来,因为附件尺寸最大只有97K,!
发表于 2008-7-27 15:33:21 | 只看该作者
DME
发表于 2008-7-27 15:36:21 | 只看该作者
DME
发表于 2008-7-27 15:39:51 | 只看该作者
DME collapsible core design
发表于 2008-7-27 15:41:06 | 只看该作者
DME伸缩芯图纸
因为这里附件大小限制,请去https://www.jxcad.com.cn/read.php?tid=666481&fpage=2下载伸缩芯2D图纸。
GMT+8, 2025-7-1 07:17 , Processed in 0.031178 second(s), 11 queries , Gzip On, Redis On.
