查看: 16851|回复: 7
[讨论] 有关于过滤后的程序还是没有圆弧。
发表于 2008-7-28 00:42:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不知道为什么,,
  我用的是MasterCAM9.1sp2版,但是编出来的程序没有圆弧,我用的是2:1的过滤,,可是程序在机床上用时,,机器走的很慢,,这是我现在用的后处理。。
spaces      : 1     #Number of spaces to add between fields
omitseq     : no    #Omit sequence numbers?
seqmax      : 9999  #Max. sequence number
arcoutput   : 0     #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype     : 2     #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
breakarcs   : 2     #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
do_full_arc : 1     #Allow full circle output? 0=no, 1=yes
helix_arc   : 1     #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
compwarn    : 1     #Warn if cutter comp applied on arc, 0=no, 1=yes
miscerror   : 0     #Error out if Misc Values button is disabled, 0=no, 1=yes
maxrad      : 999   #Maximum arc radius
hel_2100    : no    #Acramatic 2100 style helical moves, 0=no, 1=yes
usecanned   : yes   #Use canned drilling cycles?  Set to no for long output.
force_dpts  : no    #Force XY output on all drilling lines including cycle call?
haas_drill  : 0     #Haas style peck drill, 0=no, 1=yes
wcstype     : 2     #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off
force_wcs   : yes   #Force WCS output at every toolchange?
stagetool   : 0     #0 = Do not pre-stage tools, 1 = Stage tools
tool_table  : 1     #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View #
output_z    : yes   #Output Z Min and Z Max values (yes or no)
cool_zmove  : yes   #Coolant off with last move
use_pitch   : 0     #0 = Use feed for tapping, 1 = Use pitch for tapping
tap_feed    : 0     #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places
maxfeedpm   : 500   #Limit for feed in inch/min
maxfeedpm_m : 10000 #Limit for feed in mm/min
use_gear    : 0     #Output gear selection code, 0=no, 1=yes
max_speed   : 10000 #Maximum spindle speed
min_speed   : 50    #Minimum spindle speed
sextnc      .NC     #NC extension override
vmc         : 1     #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x    : 0     #Default Rotary Axis Orientation, See ques. 164.
                    #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 1     #Axis signed dir, 0 = CW positive, 1 = CCW positive
ret_on_indx : 1     #Machine home retract on rotary index moves, (0 = no, 1 = yes)
index       : 0     #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable      : 5     #Degrees for each index step with indexing spindle
one_rev     : 0     #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)
lock_codes  : 0     #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes)
use_frinv   : 0     #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
maxfrdeg    : 2000  #Limit for feed in deg/min
maxfrinv    : 999.99#Limit for feed inverse time
frc_cinit   : 1     #Force C axis reset at toolchange
ctol        : 225   #Tolerance in deg. before rev flag changes
ixtol       : .01   #Tolerance in deg. for index error
frdegstp    : 10    #Step limit for rotary feed in deg/min
发表于 2008-7-28 09:51:26 | 只看该作者
后处理选择有问题,选默认的Fanuc试一试。。。
发表于 2008-7-28 12:53:08 | 只看该作者
回复 2楼 jintjint 的帖子
我试了,,
  还是一样的啊。。没有改进啊。
    我一般用的角度是45度。。
发表于 2008-7-28 21:17:51 | 只看该作者
mc里面平行走曲面除了0,90,180,270其他角度过滤没用的
发表于 2008-7-28 22:02:33 | 只看该作者
你 能说说你的机床什么时候生产的吗?
发表于 2008-7-29 01:46:00 | 只看该作者
回复 5楼 wudliang 的帖子
J是现在的新的机器啊……
    FANUC,,,,,,,,和,三凌的啊。。
发表于 2008-7-29 01:47:05 | 只看该作者
回复 4楼 huanglonghl 的帖子
那有什么办法吗……
发表于 2008-7-29 14:08:22 | 只看该作者
平行走45度怎么可能会有圆弧?
GMT+8, 2025-2-23 16:40 , Processed in 0.026658 second(s), 10 queries , Gzip On, Redis On.
