53表面粗糙度比较样块抛丸、喷砂加工表面
roughness comparison specimens shot blasted and blasted surfaces
54产品结构几何量计术规范(GPS)geometrical product specifications(GPS)
55表面结构 surface texture
56接触式仪器的标称特性 nominal characteristics of contact instruments
57公法线千分尺micrometer for mearsuring root tangent lenghths of gear teeth
58最大允许误差 maximum permissible error
59圆柱直齿渐开线花键量规 gauges for straight cylindrical involute splines
60齿厚游标卡尺 Gear tooth vernier
calipers
61齿轮渐开线样板the involute master of gear
62齿轮螺旋线样板 the helix master of gear
63矩形花键量规 gauges for straight –sided splines
64测量蜗杆 master worm
65万能测齿仪 universal gear measuring instrument
66万能渐开线检查仪universal involute measuring instrument
67齿轮齿距测量仪gear circular pictch measuring instrument
68万能齿轮测量机 Universal gear measuring machine
69齿轮螺旋线测量仪gear helix measuring instrument
70便携式齿轮齿距测量仪 manual gear circular pitch measuring instrument
71便携式齿轮基节测量仪manual gear base pitch measuring instrument
72立式滚刀测量仪vertical hob measuring instrument
73齿轮双面啮合综合测量仪Gear dual-flank measuring instrument
74齿轮单面啮合整体误差测量仪Gear single-flank meshing integrated error measuring instrument
75梯形螺纹量规 gauges for metric trapezoidal screw threads
76工作螺纹量规work gauges for metric trapezoidal screw threads
77校对螺纹量规check gauges for metric trapezoidal screw threads
78.梯形螺纹量规型式与尺寸 Types and dimensions of metric trapezoidal screw threads
79.普通螺纹量规型式与尺寸 Types and dimensions of gauges purpose screw threads
80.非螺纹密封的管螺纹量规 Gauges for pipe threads prcessure-tight joints are not made on the threads
81.螺纹千分尺
Screw thread micrometer
82.最大允许误差 maximum permissible error
83.间隙螺纹量规 Clearance screw gauge
84.量针
Bar gauge
85.螺纹样板 Screw thread template
86.用螺纹密封的管螺纹量规
Gauges for pipe threads where pressure-tight joints are made on the threads
87.刀具预调测量仪 精度
Accuracy of the presetting instrument
88.薄膜式气动量仪
Membrane type pneumatic measuring instrument
89.光栅线位移测量系统
Grating linear displacement measuring system
90.光栅角位移测量系统
Grating angular displacement measuring system
91.磁栅线位移测量系统
Magnet-grid linear displacement measuring system
92.量块附件
Accessories for gauge blocks
93.V形架
Vee blocks
94.比较仪座
Comparator stand
95.磁性表座
Magnetic stand
96.万能表座
Universal stand for dial indicator
资料来源:好域安机械技术论坛
