查看: 16482|回复: 1
【介绍】cimatron4.21
发表于 2003-5-22 06:12:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
赏屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯?
? ELITE V4.21 ISO (c) Cimatron                   ?
瘸屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯统?
睦哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪?
Packaged @: May 2003                               <xx/50> :..Number of Disks
Cracker...: LND TEAM                            NT/2K/XP :.Operating System
Packager..: LND TEAM                                FlexLM :Serial/Protection
Supplier..: LND TEAM
?                                                     Product Description ?
帜哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪馁?
  Cimatron E - maximum performance for the tooling industry
  Cimatron抯 CAD/CAM environment was designed with the tooling industry in
  mind. Mold and die makers can benefit from new levels of speed and
  flexibility in all stages of the tooling process.
  Cimatron E contains a set of easy-to-use 3D design tools with unsurpassed
  power. The unified solid-surface-wireframe environment allows the user to
  manipulate imported data or create conceptual part designs with equal ease.
  Throughout the modeling stage, Cimatron E provides integrated tools to split
  part geometry, find and implement engineering changes, create slides and
  inserts, and detail tooling components and electrodes.
  During manufacturing, Cimatron E implements 2.5- to 5-axis toolpaths using
  high-speed milling, knowledge of stock remaining and templates to
  drastically reduce programming and machining time.
  More Infos: https://www.cimatron.com/html/CAD_CAM_products/cimatronE.asp
发表于 2003-5-22 17:09:38 | 只看该作者
TOTOB ,HELLO
GMT+8, 2025-10-18 05:37 , Processed in 0.053532 second(s), 11 queries , Gzip On, Redis On.
