查看: 15543|回复: 1
【求助】关于pro/M的使用问题!麻烦哪个前辈翻译一下!
发表于 2003-5-22 07:58:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Before running the Motion engine program, you need to verify that the C-compiler is installed and working.
You do not directly invoke the Motion engine program. If you set the environment variable MM_HOSTNAME, Pro/MECHANICA first attempts to connect to a running Pro/MECHANICA MOTION network engine on the computer that MM_HOSTNAME specifies. If it cannot connect to the network engine, Pro/MECHANICA starts a local private engine. The Motion engine then launches another program called the simulator.
After Pro/MECHANICA establishes an engine connection, it remains connected for the rest of the session, or until you make a change to the model. This means that you can request any number of analyses.
The engine reports the analysis results to Pro/MECHANICA through the same connection established when you started the first analysis. This means that you can view the animations of the analysis in real time as the engine generates the results. Pro/MECHANICA also enters the results into a database for later, more detailed, postprocessing.
发表于 2003-5-22 11:27:32 | 只看该作者
很简单啊!
在运行“pro/m"之前,请检查有没有安装VC的编译器。
GMT+8, 2025-4-30 18:29 , Processed in 0.046493 second(s), 11 queries , Gzip On, Redis On.
