查看: 20576|回复: 16
[讨论] 关于右键菜单与宏的完美形式
发表于 2008-8-13 01:42:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
见图。。。
[ 本帖最后由 xunpeng 于 2008-8-15 14:35 编辑 ]
发表于 2008-8-13 01:49:09 | 只看该作者
关于右键菜单与宏的完美形式
发表于 2008-8-13 01:50:53 | 只看该作者
录得铜公开粗宏如下:
RESET ALL
DIALOGS MESSAGE OFF
FORM BLOCK
EDIT BLOCK ALL UNLOCK
EDIT BLOCK RESET
EDIT BLOCK ZMIN LOCK
EDIT BLOCK RESETLIMIT "0.2"
EDIT BLOCK RESET
EDIT BLOCK ZMAX LOCK
EDIT BLOCK RESETLIMIT "10"
EDIT BLOCK RESET
BLOCK ACCEPT
CREATE BOUNDARY ; BLOCK FORM BOUNDARY
RENAME BOUNDARY "1" "T"
EDIT BOUNDARY "T" CALCULATE
EDIT BOUNDARY "T" SURFACES ACCEPT BOUNDARY ACCEPT
RENAME BOUNDARY "T" "Q15"
RENAME BOUNDARY "Q15" "Q14"
RENAME BOUNDARY "Q14" "Q13"
RENAME BOUNDARY "Q13" "Q12"
RENAME BOUNDARY "Q12" "Q11"
RENAME BOUNDARY "Q11" "Q10"
RENAME BOUNDARY "Q10" "Q9"
RENAME BOUNDARY "Q9" "Q8"
RENAME BOUNDARY "Q8" "Q7"
RENAME BOUNDARY "Q7" "Q6"
RENAME BOUNDARY "Q6" "Q5"
RENAME BOUNDARY "Q5" "Q4"
RENAME BOUNDARY "Q4" "Q3"
RENAME BOUNDARY "Q3" "Q2"
RENAME BOUNDARY "Q2" "Q1"
FORM FEEDRATE
EDIT RPM "800"
EDIT FRATE "2500"
EDIT PRATE "800"
EDIT RSPEED "6000"
FEEDRATE ACCEPT
FORM TOOLZHEIGHTS
EDIT RMOVES SKIM
EDIT ISAFZ  "20"
EDIT ISTAZ  "5"
EDIT TOOLPATH SAFEAREA RESET
EDIT RMOVES SKIM
EDIT ISAFZ  "5"
EDIT ISTAZ  "0.5"
TOOLZHEIGHTS ACCEPT
FORM LEADLINK
EDIT TOOLPATH LEADS PAGE ZHEIGHTS
EDIT TOOLPATH LEADS SKIMDIST "5"
EDIT TOOLPATH LEADS PLUNGEDIST "0.5"
EDIT TOOLPATH LEADS PAGE LEADIN
EDIT TOOLPATH LEADS LEADIN RAMP
FORM PMLLEADINRAMP
EDIT TOOLPATH LEADS LEADIN RAMPOPT ZIGANGLE "3"
EDIT TOOLPATH LEADS LEADIN RAMPOPT HEIGHT_INCREMENT "0.5"
LEADINRAMP ACCEPT
EDIT TOOLPATH LEADS PAGE LEADSOUT
EDIT TOOLPATH LEADS LEADOUT HARC
EDIT TOOLPATH LEADS LEADOUT ANGLE "60"
EDIT TOOLPATH LEADS LEADOUT LRAD "1"
EDIT TOOLPATH LEADS PAGE LINK
EDIT TOOLPATH LEADS LINK THRESHOLD "20"
EDIT TOOLPATH LEADS LINK TANGENT
EDIT TOOLPATH LEADS LONGLINK SKIM
EDIT TOOLPATH LEADS SAFELINK INCR
LEADS ACCEPT
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI
"3D-Area-Clearance\Offset-AreaClear-Model.ptf"
ACTIVATE TOOL "D20"
RENAME TOOLPATH "1" "D20_C"
EDIT RTOLERANCE "0.04"
EDIT RTHICKNESS AXIAL_RADIAL ON
EDIT RTHICKNESS "0.1"
EDIT RTHICKNESS AXIAL "0.1"
EDIT OVER "15"
EDIT ZHEIGHTS AUTOMATIC STEPDOWN "0.8"
EDIT AREAFILTER ON
EDIT AREAFILTERVALUE "0.65"
EDIT LMOVES RAMP
FORM RAMP
EDIT RAMP ZIGANGLE "3"
RAMP ACCEPT
EDIT SLICEARCFIT ON
SET AREACLEAREXPERT
EDIT ALLOWTOOLOUTSIDEBLOCK OFF
EDIT ALLOWTOOLOUTSIDEBLOCK ON
UNSET AREACLEAREXPERT
EDIT TOOLPATH "D20_C" REAPPLYFROMGUI
FORM BLOCK
EDIT BLOCK RESETLIMIT "30"
EDIT BLOCK RESET
BLOCK ACCEPT
CREATE BOUNDARY ; SILHOUETTE FORM BOUNDARY
EDIT BOUNDARY "T" TOOL NAME "D20"
EDIT BOUNDARY "T" TOLERANCE "0.01"
EDIT BOUNDARY "T" THICKNESS AXIAL_RADIAL ON
EDIT BOUNDARY "T" THICKNESS -0.5
EDIT BOUNDARY "T" THICKNESS AXIAL 0
FORM LEADLINK
EDIT TOOLPATH LEADS LEADIN HARC
EDIT TOOLPATH LEADS LEADIN ANGLE "90"
EDIT TOOLPATH LEADS LEADIN LRAD "8"
EDIT TOOLPATH LEADS LEADOUT COPY
EDIT TOOLPATH LEADS LINK THRESHOLD "50"
LEADS ACCEPT
"Finishing\Constant-Z-Finishing.ptf"
ACTIVATE TOOL "D20"
RENAME TOOLPATH "1" "D20_C1"
EDIT FTOLERANCE "0.04"
EDIT FTHICKNESS AXIAL_RADIAL ON
EDIT FTHICKNESS "0.1"
EDIT FTHICKNESS AXIAL "0"
EDIT BOUNDARYSIDE OUTSIDE
EDIT STEPDOWN "0.8"
EDIT PAR 'CornerRadius.Active' 1
EDIT TOOLPATH "D20_C1" REAPPLYFROMGUI
FORM FEEDRATE
EDIT RPM "1000"
EDIT FRATE "800"
EDIT PRATE "400"
EDIT RSPEED "6000"
FEEDRATE ACCEPT
ACTIVATE TOOL "D20"
RENAME TOOLPATH "1" "D20_J"
EDIT RTOLERANCE "0.01"
EDIT RTHICKNESS "0.3"
EDIT RTHICKNESS AXIAL "0"
EDIT OVER "15"
EDIT TRIM INSIDE
SET AREACLEAREXPERT
EDIT AREACLEAR TYPE FLAT
EDIT IGNORE_HOLES ON
EDIT TOOLPATH "D20_J" REAPPLYFROMGUI
FORM FEEDRATE
EDIT RPM "1000"
EDIT FRATE "800"
EDIT PRATE "400"
EDIT RSPEED "6000"
FEEDRATE ACCEPT
FORM LEADLINK
EDIT TOOLPATH LEADS PLUNGEDIST "1"
EDIT TOOLPATH LEADS INCREMENT_FROM_STOCK N
EDIT TOOLPATH LEADS LEADIN LRAD "10"
LEADS ACCEPT
"3D-Area-Clearance\Profile-AreaClear-Model.ptf"
ACTIVATE TOOL "D20"
RENAME TOOLPATH "1" "D20_J1"
EDIT RTHICKNESS "0"
EDIT ZHEIGHTS AUTOMATIC STEPDOWN "200"
EDIT ZHEIGHTS AUTOMATIC CALCFLATS OFF
EDIT TRIM OUTSIDE
EDIT PCUTDIR CLIMB
EDIT FINALPROFILEPASS ON
EDIT FINALPROFILEPASS ALLOWANCE "0.05"
EDIT AREAFILTER OFF
EDIT LMOVES PLUNGE
EDIT SLICEARCFIT OFF
EDIT TOOLPATH "D20_J1" REAPPLYFROMGUI
FORM PATHLISTS
PATHSELECTOR PATHLISTS LISTCHANGE OUTPUT
PATHSELECTOR PATHLISTS ADDTOP PROJSELECTOR
"D:\NC"
PATHLISTS ACCEPT
FORM OPTIONS
EDIT OPTIONS TAB OPTNCPROGRAM
EDIT NCPROGRAM PREFERENCES OPT_EXTENSION "machine fanuc15m"
EDIT NCPROGRAM PREFERENCES EXTENSION "machine fanuc15m" "NC"
OPTIONS ACCEPT
FORM NCPREFERENCES
PATHSELECTOR PATHLISTS LISTCHANGE OUTPUT PATHSELECTOR PATHLISTS CLEAR PATHSELECTOR PATHLISTS ADD PROJSELECTOR
"D:\NC"
EDIT NCPROGRAM PREFERENCES TAPEOPTIONS FILEOPEN
"C:/dcam/config/ductpost/machine fanuc15m.opt"
NCPREFERENCES APPLY
NCPREFERENCES ACCEPT
EXPLORER SELECT Toolpath "D20_C" NEW
CREATE NCPROGRAM "D20_C" EDIT NCPROGRAM "D20_C" APPEND TOOLPATH "D20_C" DEACTIVATE NCPROGRAM
EXPLORER SELECT Toolpath "D20_J" NEW
CREATE NCPROGRAM "D20_J" EDIT NCPROGRAM "D20_J" APPEND TOOLPATH "D20_J" DEACTIVATE NCPROGRAM
EXPLORER SELECT Toolpath "D20_C1" NEW
EDIT NCPROGRAM "D20_C" INSERT Toolpath "D20_C1" LAST
EXPLORER SELECT Toolpath "D20_J1" NEW
EDIT NCPROGRAM "D20_J" INSERT Toolpath "D20_J1" LAST
发表于 2008-8-13 01:55:03 | 只看该作者
有这方面兴趣的朋友不妨来41691195QQ群走走。。。。
发表于 2009-3-26 11:01:32 | 只看该作者
非常好,谢谢你
发表于 2009-3-29 22:49:48 | 只看该作者
刚开始学,好好跟楼主学习学习!
发表于 2009-3-30 22:08:57 | 只看该作者
看一下
看一下
发表于 2009-3-30 22:36:12 | 只看该作者
不太懂,学习.
发表于 2009-3-31 01:46:57 | 只看该作者
想学习一下
发表于 2009-6-6 07:52:09 | 只看该作者
ding ~~~~~~~~~~~~~~~~~~~~~~
GMT+8, 2025-4-23 20:51 , Processed in 0.024455 second(s), 11 queries , Gzip On, Redis On.
