查看: 17877|回复: 11
[求助] LED灯
发表于 2008-8-16 15:41:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位谁做过LED灯。请发表些意见和资料,谢谢。
发表于 2008-9-19 16:54:50 | 只看该作者
我在做,有什么问题吗
发表于 2008-10-9 13:22:52 | 只看该作者
我也需要这方面的资料
发表于 2008-10-9 13:39:14 | 只看该作者
我在做,发表什么意见?
随便问一下谁有10W的LED,效能70 Lm/W及其以上的,白光。
发表于 2008-10-9 14:21:04 | 只看该作者
High Luminous Efficacy
White LED Emitter
LZ4-00CW10
Key Features
􀂃 High Luminous Efficacy 10W White LED
􀂃 Ultra-small foot print – 7.0mm x 7.0mm x 4.1mm
􀂃 Surface mount ceramic package with integrated glass lens
􀂃 Electrically neutral thermal path
􀂃 Very low Thermal Resistance (3°C/W)
􀂃 Individually addressable die
􀂃 Very high Luminous Flux density
􀂃 Spatial color uniformity across radiation pattern
􀂃 New industry standard for Lumen Maintenance (>90% at 100,000 Hours)
􀂃 JEDEC Level 2 for Moisture Sensitivity Level
􀂃 Autoclave complaint (JEDEC JESD22-A102-C)
􀂃 Lead (Pb) free and RoHS compliant
􀂃 Reflow solderable (up to 6 cycles)
􀂃 Emitter available on Standard MCPCB (optional)
Typical Applications
􀂃 Architectural lighting
􀂃 Street lighting
􀂃 Stage and Studio lighting
􀂃 Task and Accent lighting
􀂃 Refrigeration lighting
􀂃 Portable lighting
Description
The LZ4-00CW10 White LED emitter provides 10W power in an extremely small package. With
a 7.0mm x 7.0mm x 4.1mm ultra-small footprint, this package provides exceptional luminous
flux density. LedEngin’s patent-pending thermally insulated phosphor layer provides spatial
color uniformity across the radiation pattern and a consistent CCT over time and temperature.
LedEngin’s LZ4-00CW10 LED offers ultimate design flexibility with individually addressable die
as well as separate electrical and thermal paths. The high quality materials used in the package
are chosen to optimize light output and minimize stresses which results in monumental reliability
and lumen maintenance. The robust product design thrives in outdoor applications with high
ambient temperatures and high humidity.
[ 本帖最后由 spearli 于 2008-10-9 14:22 编辑 ]
发表于 2008-10-9 14:41:53 | 只看该作者
帮顶.............
发表于 2008-10-9 14:42:22 | 只看该作者
帮顶.............
发表于 2008-10-9 16:26:43 | 只看该作者
请问出非洲,印度要做安规吗?我们LED灯是12V镍氢电池,有市电充电器还需要做认证吗?现在各国都还没有出专门的LED标准,你们是如何处理的?谢谢。
发表于 2009-6-20 11:15:31 | 只看该作者
下来看看。。。。。。 学习中~~~~
发表于 2009-6-26 14:12:15 | 只看该作者
有透镜的机械图吗?
GMT+8, 2025-4-25 16:55 , Processed in 0.036573 second(s), 11 queries , Gzip On, Redis On.
