查看: 17728|回复: 1
[讨论] 有人玩过simdesigner for catia吗
发表于 2008-9-1 23:56:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在sd motion工作台里进行模型的动力学仿真,就算是一个很简单的机构,只要在两个part之间添加Body/Body Contact约束以后simulation的速度就会变得奇慢无比,算1帧要等很久很久,去掉Body/Body Contact约束以后倒是飞快,但是这样就没法模拟实体与实体的接触和碰撞了,这是什么问题啊?
我的平台是CATIA v5r17 + simdesigner
发表于 2008-9-1 23:58:30 | 只看该作者
The Geometry Engine for Contacts is User-Written
|                                 Model Title                                 |
****** Performing Dynamic Simulation using Gstiff Integrator ******
  Begin Simulation
   The system is modelled with INDEX-3 DAEs.
   The integrator is GSTIFF, CORRECTOR = original
   Integration error =    1.000000E-03
   Simulation      Step        Function    Cumulative   Integration
      Time         Size       Evaluations  Steps Taken    Order
   ___________  ___________   ___________  ___________    _____
   0.00000E+00  1.00000E-04            0            0       1
   4.00000E-01  3.44984E-04         5122         1336       4
   8.00000E-01  4.34622E-04        10368         2697       4
   1.20000E+00  2.03271E-04        16068         4166       4
   1.60000E+00  3.77543E-04        21775         5648       4
   2.00000E+00  4.31744E-04        27436         7115       4
  End Simulation
Finished -----
Elapsed time = 1784.82s,  CPU time = 1700.41s,  95.27%
这是模拟完成以后的信息,6步居然用了快半个小时
GMT+8, 2025-4-25 16:13 , Processed in 0.028963 second(s), 14 queries , Gzip On, Redis On.
