查看: 15695|回复: 0
[求助] 关于TUBE的问题
发表于 2008-9-4 23:25:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位高手可以帮忙看一下应该怎么改,实现:点击曲线,生成管道。现在这个程序只能生成一次管道,再点就不管用了
#include <stdio.h>
#include <uf.h>
#include <uf_modl.h>
#include <uf_ui.h>
static int sel_init_proc(UF_UI_selection_p_t select,void *user_data)
   int err,num_tripels=2;
   UF_UI_mask_t mask_triples[]={UF_spline_type,0,0,UF_line_type,0,0,};
   err=UF_UI_set_sel_mask(select,UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,
    num_tripels,mask_triples);
   if(err==0) return UF_UI_SEL_SUCCESS;
   else return UF_UI_SEL_FAILURE;
static void do_ugopen_api(void)
    char cue[] = "选择曲线";
    char title[] = "选择曲线";
    int response, count, i;
    tag_p_t obj_line;
int obj_tube;
    char*body_limit[2]={"outer_diameter=16","inner_diameter=0"};
    tag_t generators[1];
    UF_MODL_SWEEP_TRIM_object_p_t trim_data = NULL;
    UF_FEATURE_SIGN   mode_sign = UF_NULLSIGN;
    if(((UF_UI_select_with_class_dialog(cue, title, UF_UI_SEL_SCOPE_WORK_PART,
          sel_init_proc, NULL, &response, &count, &obj_line))) == 0)
         printf("obj_line count = %d\n",count);
         if (response == UF_UI_OK && count > 0)
             for (i=0; i<count; i++)
                 printf("obj_line tag = %d\n", obj_line);
     UF_DISP_set_highlight(obj_line, 0);
  generators[0] =obj_line;
     (UF_MODL_create_trimmed_tube(generators,1, trim_data,
     body_limit,mode_sign, &obj_line, &obj_tube));
     UF_free(obj_line);
void ufusr(char *param, int *retcode, int param_len)
  if (!(UF_initialize()))
    do_ugopen_api();
    (UF_terminate());
int ufusr_ask_unload(void)
  return (UF_UNLOAD_IMMEDIATELY);
GMT+8, 2025-4-8 19:47 , Processed in 0.020077 second(s), 12 queries , Gzip On, Redis On.
