查看: 16852|回复: 5
有谁知道CATIA V4 SURFACE2的使用
发表于 2002-5-6 15:42:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人在使用CATIAV4时,遇到一个问题:CATIAV4   SURFACE2功能中
SUR2+CREAT+CRV+ CRV CRV 时无法对边缘施加曲面切矢连续,
请问是否能施加,如何施加???
发表于 2002-5-6 21:13:24 | 只看该作者
添加0度的angle约束,compute的时候再选相应的reference  sur/fac/ski
发表于 2002-5-18 13:33:25 | 只看该作者
I had a V4 manual PDF regarding Surf 2, it should come along with your cd, the manual mention all command and option regarding surf2.
发表于 2002-5-20 12:05:54 | 只看该作者
我也有V4的pdf资料,但不理解,你知道SUR2的理论基础可查看哪些书吗???
发表于 2002-5-21 16:07:53 | 只看该作者
上班做了一下,daniel_pan说的对,加 0 angle约束,但你的G1和G2也和所选曲面切矢连续,这是必须的。
发表于 2002-5-23 01:11:41 | 只看该作者
If you had attent the CATIA trainning , you should had some idea on surf 2 function. I had alot of book regarding Catia V4 tranning. too bad my line in Malaysia is too slow, i wont able to uplload all those files to you.
Learning the command is still not very hard, but to become good is very hard .
GMT+8, 2025-4-5 11:43 , Processed in 0.057474 second(s), 12 queries , Gzip On, Redis On.
