查看: 21437|回复: 1
[求助] cimatron E8.5的安装
发表于 2008-9-19 16:56:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用 Cimatron E8.5里的crack文件安装不上用8.0可以.但是好象少了一些功能没有曲面的一排功能.汉化也不行造型模块没能汉化
#FEATURE CORE_ELECTRODE cima-d 8 31-dec-2012 uncounted \
#        HOSTID=00e0610b379b ISSUER="Team oDDiTy" SIGN=6DBC437817BE
FEATURE CORE_STANDARD cima-d 8 31-dec-2012 uncounted \
PACKAGE ODT_SHOOT_PACKAGE cima-d 8 COMPONENTS="$oDDiTy_rOX SLA CORE \
        CONCURRENT_DESIGN CATALOGTOOL KINEMATICS QSPLIT DIE_FORM \
        DIE_BLANK DIE_STRIP DIE_TOOLS DIE_PLOT DIE_SET DIE_LABEL \
        2X-MILL 3X-MILL 3X_SIMULATOR 5X_SIMULATOR NC-LINK CAD_MODE \
        QUICKDRILL MACHINE_SIM MOLDDESIGN QELECTROD QCOMPARE AUTODRAW \
        AUTOMATED_DRILL BEND CATIA CATIAR2D CATIAR3D CATIAW2D CATIAW3D \
        CIMACABLE CIMADEK CIMADEK-NC CIMADEK-RUN CIMARENDER CIMIT-M \
        CIMIT-N CIMIT-D CIMIT-MD CIMIT-MDN CIMIT-MN CORE-M CORE-X \
        CPDM DIE_FLANGE E_STAMP QUICK_NC GPF DRAFT EDMS-LINK \
        EDM_SETUP_WIZARD EDM_WIZ_AGIE EDM_WIZ_DPC EDM_WIZ_INGERSOL \
        EDM_WIZ_MITSUBISHI EDM_WIZ_CHARMILLE EDM_WIZ_MAKINO API_DE_Global \
        API_DE_SPLINE API_DE_NADELSTICH API_DE_MESSEN API_DE_ReadInventor \
        ELECTRODE FAST_BLANK FIKUS_IGUS FUSION_FULL GPP2_3X GPP2_5X \
        GPP2_DEV_FP2 GPP_DEV_EX2 GUN_DRILL LATHE LATHE_2X LATHE_3X \
        LATHE_PP_COMPILER MACHINE_SIM_CONFIG MACRO MICROSCRIBE_IF \
        MICRO_3X MICRO_5X MOLD-EXPERT MOLDBASE3D MULTI-USER-1 \
        MULTI-USER-2 MX-MOTION-EDITOR NC_UNDERCUT NESTING \
        NETWORK_ENABLED PAR-SHAPE PARASOLID_READ PARASOLID_SAT \
        POST_CONFIG POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT \
        QCON_C QCON_Q QCON_S QUICKCONCEPT RD-PTC RE-ENGE R_CATIA5 \
        R_CATIA_2D R_CATIA_SAT R_IGES R_IGES_SAT R_INVENTOR \
        R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT R_UG R_VDA \
        R_VDA_SAT R_VRML SHOP-NC SIMULATOR SOLFAST_FULL SOLID \
        SOLID-ASSEMBLY STEP_READ STEP_WRITE SURFM TACFAST_FULL \
        VERIFIER V_CONTROLLER WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE \
        W_CATIA5 W_CATIA_SAT W_IGES W_IGES_SAT W_PARASOLID W_STEP \
        W_STEP_SAT W_UG W_VDA W_VDA_SAT W_VRML X-CIMADEK X-CIMADEK-RUN \
        DIE_PLOT_THICK DIE_PLOT_SAFETY 5X_AEROSPACE 5X_TRIM 4X-CONT \
        5X-CONT 2X-WIRE 4X-WIRE ABIANT IGES GPP FEM VDA DXF 2D-TO-3D \
        SAT DWG DMS TEMP_KEY_CODE UGR3D MX_MOTION_BUILDER STL \
        ADVANCED_ASSEMBLY 2X_MILL_LITE 3X_MILL_LITE" SIGN=E254603088CC
FEATURE ODT_SHOOT_PACKAGE cima-d 8 31-dec-2012 uncounted \
        HOSTID=00e0610b379b ISSUER="Team oDDiTy" SIGN=2CBCB4507F72
PACKAGE ODT_CATALOGS cima-d 8 COMPONENTS="CATALOG_DANLY_INCH \
        CATALOG_DANLY_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \
        CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \
        CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \
        CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \
        CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \
        CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \
        CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \
        CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \
        CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \
        CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \
        CATALOG_UNI CATALOG_VAP CATALOG_CN_FUTABA CATALOG_IT_PEDROTTI\
        CATALOG_IT_SIDECO CATALOG_IT_SKF CATALOG_IT_SYSTEM3R \
        CATALOG_IT_TVMP CATALOG_IT_UNI CATALOG_IT_STAMPI \
        CATALOG_NL_STRACK_MM CATALOG_DE_MEUSBURGER CATALOG_PEDROTTI" \
        SIGN=5DF98D6EF1C0
FEATURE ODT_CATALOGS cima-d 8 31-dec-2012 uncounted \
        HOSTID=00e0610b379b ISSUER="Team oDDiTy" SIGN=7E12FA448FAA
FEATURE CHINESE_TRANSLATION cima-d 8 31-dec-2012 uncounted \
        HOSTID=00e0610b379b ISSUER="Team oDDiTy" SIGN=85CE
00e0610b379b这是我的网卡地址.crack我下了很多还是看到论坛里面有篇文章用8.0的crack后来才装上
发表于 2008-9-19 21:46:27 | 只看该作者
你用8.5的CRACK不就得了!
GMT+8, 2025-4-29 05:56 , Processed in 0.026606 second(s), 10 queries , Gzip On, Redis On.
