查看: 21825|回复: 10
[原创] API 二次开发(抛砖引玉)
发表于 2008-9-28 17:30:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在论坛里没看到有人做过二次开发,但我知道有高手在背后默默的看着。
我在此抛砖引玉。
花费了半小时,调出了一个 VB程序。如果你机子上有 TS2008 可以试试 我编的哦。
点击“拉伸出圆柱”按钮后, 看下你的D盘,是不是多出一个文件。那就是生成的圆柱实体了。
参与人数 1技术 +1 收起 理由
plusqq + 1 我很赞同
发表于 2008-9-28 17:32:30 | 只看该作者
VB 源程序代码如下
Private Sub Command1_Click()
Dim TopApp As TopSolid.Application
Dim TopDoc As TopSolid.DocumentDesign
' connect Visual Basic with TopSolid
' if TopSolid isn't open, it will open a new session of TopSolid
Set TopApp = New TopSolid.Application
' create a new document *.top
Set TopDoc = TopApp.Documents.Add("top")
Dim TopCircle As TopSolid.Curve
' Create a basic circle
' Centre = 0, 0, 0
' X axis = 1, 0, 0
' Y axis = 0, 1, 0
' Radius = 0.01
Set TopCircle = TopDoc.Curves.AddBasicCircle(0, 0, 0, 1, 0, 0, 0, 1, 0, 0.01)
' Set the name of the circle
TopCircle.Element.Name = "Circle_1"
' Free the memory
Set TopCircle = Nothing
Dim TopShape As TopSolid.Shape
Dim TopElt As TopSolid.Element
On Error Resume Next
' Search the curve to do the extruded
Set TopElt = TopDoc.Document.SearchElementByName("Circle_1")
' "cast" the element in circle
Set TopCircle = TopElt
If TopCircle Is Nothing Then
    'error management
    Exit Sub
End If
' Create a basic extruded
' Curve = Circle 1
' Z axis = 0, 0, 1
' Length = 0.02
Set TopShape = TopDoc.Shapes.AddBasicExtruded(TopCircle, 0, 0, 1, 0.02)
' Change the color of the shape
TopShape.Element.Color = topColorBlue
' Free the memory
Set TopShape = Nothing
Set TopElt = Nothing
' Save the document with the name how_to_start.top
' If the document is modified, TopSolid must ask the user
TopDoc.Document.SaveAs "d:\how_to_start2.top", True
' TopSolid must save the modification(first 'True')
' TopSolid must ask the user (second 'True')
TopDoc.Document.Close True, True
' Close TopSolid
TopApp.Quit
End Sub
Private Sub Form_Unload(Cancel As Integer)
' Free memory
Set TopDoc = Nothing
Set TopApp = Nothing
End Sub
发表于 2008-9-28 18:54:57 | 只看该作者
高.实在是高
发表于 2008-9-28 19:00:06 | 只看该作者
希望楼主在出图的线型粗细方面做些变动.TS的不是很方便啊
发表于 2008-9-28 19:55:47 | 只看该作者
原帖由 三师兄 于 2008-9-28 19:00 发表
二维出图,我还没有研究过,不过看有个文章上写的,是可以后期修改的,包括线型和颜色,粗细等。
发表于 2008-9-28 20:10:33 | 只看该作者
顶一个,希望多点这种人才.
发表于 2008-9-30 08:33:55 | 只看该作者
希望楼主能开始出像Inventor草图那么方便的绘图方式
发表于 2008-9-30 10:40:39 | 只看该作者
楼主贴个api教程呢
发表于 2008-9-30 23:48:39 | 只看该作者
只有北京宇航做过二次开发
发表于 2008-10-1 00:05:44 | 只看该作者
看看学习一下啊
GMT+8, 2025-4-20 01:14 , Processed in 0.115775 second(s), 11 queries , Gzip On, Redis On.
