查看: 16481|回复: 3
会使用Pro/MECHANICA的朋友过来帮忙!急!!!
发表于 2003-5-27 08:27:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
好象在wildfire 中的Mechanism导入motion中作分析时,对连接轴的驱动器设定初始位置时,不能对Mechanism所做的副的连接不认!不能做修改!
如图所示,我想使用set zeros时,或者编辑connections时都出现这样的错误!
发表于 2003-5-27 08:29:13 | 只看该作者
2001版本有这一个问题吗?
说是不承认Mechanicam所设定的连接副?
另外,怎样将pro/E的整个装配(和所有零件)一起导入Pro/Mechanica的motion当中?
在Pro/MECHANICA实现装配容易吗?
发表于 2003-5-27 08:31:07 | 只看该作者
使用strature时得错误,水能帮忙解释一下!
全英文的信息,我不太懂!在运行优化设计时出现:
The model is insufficiently constrained for the analysis.
Please review the element connections, properties, and
constraints.
You may be able to locate your model's problem area by
using Pro/MECHANICA database ID numbers.  Each Pro/MECHANICA
entity has an ID number. The following ID numbers
are associated with this error:
25024
26940
26954
26966
26980
26988
27042
27054
27106
27902
27970
27980
27984
27988
For inFORMation on locating the entities associated with
these numbers and identifying the problem, you can refer to
the following documentation:
     book: Pro/MECHANICA "Strategies Guide"
  chapter: "Strategies and Technical Tips for Structure
           and Thermal"
  section: "Results"
    topic: "Insufficiently Constrained Models"
发表于 2009-4-27 10:00:28 | 只看该作者
有点乱啊!!
GMT+8, 2025-4-30 14:08 , Processed in 0.022211 second(s), 11 queries , Gzip On, Redis On.
