查看: 16287|回复: 3
[求助] 请教uf_modl_replace_features函数一个参数设置?(呼唤高手)
发表于 2008-10-26 16:12:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
parent_map这个结构体的两个参数如何设置呢?冰天雪地含泪跪谢了。
[ 本帖最后由 my_dear2002 于 2008-10-28 18:17 编辑 ]
发表于 2008-10-27 14:16:31 | 只看该作者
题目已变请大家看看这个新的问题怎么解决
[ 本帖最后由 my_dear2002 于 2008-10-27 22:47 编辑 ]
发表于 2008-11-1 14:43:15 | 只看该作者
参考example就好!
UF_MODL_replace_features_t * replm_map=NULL;
    int                          n_replm_map, i;
    UF_PART_new(part_name, units, &part_tag);
    /*  Create a cone and a cylinder
    UF_CALL(UF_MODL_create_cyl1(UF_NULLSIGN, origin, height, diam, direction, &cyl_tag));
    UF_CALL(UF_MODL_create_cone1(UF_NULLSIGN,origin, height, cone_dia, direction, &cone_tag));
    /*  Offset faces of the cylinder by 0.1"
    UF_CALL(UF_MODL_create_list(&flist));
    UF_CALL(UF_MODL_put_list_item(flist,cyl_tag));
    UF_CALL(UF_MODL_create_feature_offset(offset, flist, &offset_tag));
    UF_CALL(UF_MODL_delete_list(&flist));
    /*  Get a list of entities that must be mapped. This will be all the faces of the
        cylinder that are being used by the offset feature
    UF_CALL(UF_MODL_replace_features(&cyl_tag, 1,
                                     &cone_tag, 1,
                                     true,
                                     false,
                                     &replm_map,
                                     &n_replm_map ));
发表于 2008-11-2 18:55:29 | 只看该作者
这个例子是有问题的,你单步调试了吗?
GMT+8, 2025-4-9 16:42 , Processed in 0.054237 second(s), 12 queries , Gzip On, Redis On.
