查看: 44509|回复: 14
Alias 草绘相关事宜专贴
 关闭 [复制链接]
发表于 2003-5-29 12:16:10 | 显示全部楼层 |阅读模式
此贴用于介绍ALIAS的草绘,和手写板的要求
参与人数 1技术 +1 收起 理由
daniel_pan + 1 原创内容
发表于 2003-5-29 12:18:28 | 显示全部楼层
先介绍ALIAS的草绘流程,摘自aliaswavefront 官方站
1. 2d to 3d
Bringing your 2D drawing to 3D surface model
发表于 2003-5-29 12:23:22 | 显示全部楼层
2.working with shapes
发表于 2003-5-29 12:24:32 | 显示全部楼层
3.StudioTools and the Wacom Cintiq tablet are a perfect fit
发表于 2003-5-29 12:26:49 | 显示全部楼层
发表于 2003-5-29 12:28:00 | 显示全部楼层
5,What's the advantage of the new paint tools?
发表于 2003-5-29 12:37:52 | 显示全部楼层
关于,手写板,ALIAS官方站推荐的是WACOM牌子的手写板,同样的价钱和市场定位也有不同的系列型号
以下是Intuos2系列的,国内好像叫影拓
Intuos2 features Wacom's unique patented batteryless, cordless technology. With 1,024 levels of pen tip and eraser pressure sensitivity, nothing unlocks the power of Photoshop, Painter, Paint Shop Pro, Flash and other professional graphics applications like Intuos2. All Intuos2 pens also support pen tilt and bearing for completely natural feel and control.
发表于 2003-5-29 12:39:36 | 显示全部楼层
Cintiq系列,好像是最高档的一种了,可以直接在屏幕上作画
Wacom's Cintiq 18sx and interactive pen displays combine the advantages of an LCD monitor with the control, comfort, and productivity of Wacom's patented cordless, batteryless tablet technology. By working directly on the screen, you navigate much more quickly and naturally. Both products enable you to adjust the incline to your liking, and the 18sx stand allows you to rotate your work surface as you would a pad of paper for a completely natural work approach.
发表于 2003-5-29 12:46:10 | 显示全部楼层
还有一种,最适合俺等穷人了,国内的叫法是非凡,有非凡510和410,推荐大家使用510,俺现在用的就是510。类似下图,最近WACOM中国连不上,所以只好到他老家去找
发表于 2003-5-29 12:48:48 | 显示全部楼层
买了手写板,装好驱动后,就可以设置了,打开控制面板,找到WACOM手写板
GMT+8, 2025-4-4 03:19 , Processed in 0.064912 second(s), 11 queries , Gzip On, Redis On.
