查看: 16754|回复: 2
[求助] PROE配置文件问题
发表于 2008-11-22 09:50:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位高手:
1.CONFIG.PRO文件一行最多可以有多少字符?我的CONFIG.PRO运行后老是提示;
ERROR - d:\PTC\gt_start\config.pro, line 1318:  Line is too long.
2.请问那里有关于快捷键语法资料?
mapkey (346x446p1e1) @MAPKEY_NAME(346X446P1E1);@MAPKEY_LABEL(346X446P1E1);\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `File`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `File.psh_open`;\
mapkey(continued) ~ Activate `file_open` `commonspace_pb`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `GT(2003)`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1  `GT(2003)`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `MOLD_BASE`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1  `MOLD_BASE`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `Futaba`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `Hasco`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1  `Hasco`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `P1E1`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1  `P1E1`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `gt-346x446p1e1.drw`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1  `gt-346x446p1e1.drw`;\
mapkey(continued) ~ Activate `infodlg` `okbutton`;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewRepaint.file`;
3.EMX的config.win文件用记事本打开是没有乱码的,但现在公司用的CONFIG.WIN 打开是乱码,是不是编写好CONFIG.WIN后用啥软件编译了的?
#UGC:2 TBAR_CONF 1371 660 -1 1 1 15 2700 2006460 00000000 \
#- VERS 0 0                                                          \
#- HOST                                                              \
#- LINK                                                              \
#- DBID                                                              \
#- REVS 0,                                                           \
#- RELL 0,                                                           \
#- UOBJ_ID 0 0 0                                                     \
#- MACH                                                              \
#-END_OF_UGC_HEADER
#Pro/ENGINEER  TM  Wildfire 3.0  (c) 2006 by Parametric Technology Corporation  All Rights Reserved. M060
?@y肍L9_壹 0俬酑2e烫!!?纺竵?+疑??
发表于 2010-6-23 19:10:06 | 只看该作者
ขอบคุณครับ
发表于 2010-6-25 20:25:10 | 只看该作者
快捷键如何使用?
GMT+8, 2025-2-8 23:04 , Processed in 0.022803 second(s), 10 queries , Gzip On, Redis On.
