查看: 25582|回复: 4
[求助] NX 6.0.0.24安装问题,各位帮帮忙,谢谢了!!
发表于 2008-12-5 12:46:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用的是VISTA系统并且NX4.0运行正常,昨天我下了NX 6.0.0.24,并且按照教程操作,安装完成,但就是打不开,出现了以下问题:
还请各位高手指点,小弟不胜感激!!
发表于 2008-12-5 12:47:03 | 只看该作者
并且后台****slslog文件显示的内容(这是第一张图片显示的错误报告,也就是运行了lmtools.exe之后的)
如下:*** C:\Users\yongquan\AppData\Local\Temp\yongquan1058ed48.syslog
*** system log created by yongquan on Fri Dec 05 00:04:11 2008 中国标准时间
Node Name    :- yongquan-pc
Machine type :- GenuineIntel Family 6 Model 15 Stepping 13, Intel(R) Core(TM)2 Duo CPU     T5750  @ 2.00GHz
OS           :- Windows NT 6.0 (Workstation) (Build 6001: Service Pack 1)  Home
             :- 32 bit software version
# Processors :- 2
Memory       :- 2045Mb
Total Swap   :- 4330Mb
Free  Swap   :- 3334Mb
Running customer environment
Session is running in codeset 936 13
************** Licensing Information **************
Server ID : L N D
Webkey Access Code : 7330757468
License File Issuer : UGS
NX 6.0.0.24
Successfully loaded dynamic module F:\Program Files\UGSⅡ\NX 6.0\UGII\ugxml.dll
UGXML is using 'cp936' as the local code page
*** EXCEPTION: O/S ERROR: signal  11 in line 1679 of O:\ugnx60\ip24\src\syss\error\ind\error.cxx at Fri Dec 05 00:04:11 2008 中国标准时间
+++ General Fault Exception
Loaded module F:\Program Files\UGSⅡ\NX 6.0\ugii\dbghelp.dll 6720000 118000 6c2195b-4ee28426-94c867b0-a41b7b32-1 version = 6.5.3.7
Loaded module F:\Program Files\UGSⅡ\NX 6.0\UGII\icudt20.dll 4ad00000 7d8000 0-0-0-0-0 version = 2.0.2.0
Loaded module F:\Program Files\UGSⅡ\NX 6.0\UGII\icuuc20.dll 4a800000 51000 0-0-0-0-0 version = 2.0.2.0
Loaded module F:\Program Files\UGSⅡ\NX 6.0\UGII\xerces-c_1_6_0.dll 12000000 15a000 0-0-0-0-0 version = 1.6.0.0
Loaded module F:\Program Files\UGSⅡ\NX 6.0\]GII\ugxml.dll 66d0000 1d000 24a8861c-41074e94-4d1451b3-4e3c9e31-1=ugxml___1212737942 version = 6.0.0.24
Loaded module C:\Windows\System32\wshtcpip.dll 75880000 5000 4f115ec-4a42ecd4-73bb3bc-dcb39b0e-2 version = 6.0.6001.18000
Loaded module C:\Windows\system32\rasadhlp.dll 71040000 6000 ef7ce7f6-474cca80-1b403c8b-2363dece-2 version = 6.0.6000.16386
Loaded module C:\Windows\system32\icmp.Dll 748f0000 3000 5bc26ad9-4dd6a6f7-d65e8aa7-9d54dcbb-2 version = 6.0.6000.16386
Loaded module ·········
发表于 2008-12-5 12:50:00 | 只看该作者
这是第二张图片后台*****slslog文件显示的错误报告(也就是运行lmtools.exe之后第二次打开UG6.0的错误报告):
*** C:\Users\yongquan\AppData\Local\Temp\yongquan8a08ade.syslog
*** system log created by yongquan on Fri Dec 05 12:11:53 2008 中国标准时间
OS           :- Windos NT 6.0 (Workstation) (Build 6001: Service Pack 1)  Home
# Processors :- 2
Memory       :- 2045Mb
Total Swap   :- 4328Mb
Free  Swap   :- 3079Mb
License Error: -15
Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong [email=port@host]port@host[/email] or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       server_id
Server name:   59.53.179.126
License path:  [email=28000@yongquan-PC]28000@yongquan-PC[/email];
FLEXnet Licensing error:-15,10.  System Error: 10049 "WinSock: Invalid address"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Server ID : No Server Id
Webkey Access Code : No Webkey
License File Issuer : No Issuer
*** NOTE:: in line 57 of O:\ugnx60\ip24\src\jam\no\ind\ugflex.cxx at Fri Dec 05 12:11:53 2008 中国标准时间
+++ Licensing toolkit error -- code == -15 [Licensing Error, Cannot connect to license server system.
Feature:       server_id
NX License Error:  Cannot connect to license server system.
The server(lmgrd) has not been started yet, or UGS_LICENSE_SERVER is set to the wrong [email=port@host]port@host[/email]. [ -15 ]
*** EXCEPTION: Error code  949985 in line 1434 of O:\ugnx60\ip24\src\uginitint\no\ind\sys_ug.c at Fri Dec 05 12:11:53 2008 中国标准时间
NX License Error:  NX requires the environment variable UGS_LICENSE_SERVER
to be configured properly.  It can either be set to the value [email=port@hostname]port@hostname[/email] of the NX license server
or it can be set to point directly to a license file.
By default it will be of the form [email=28000@serverName]28000@serverName[/email].
Loaded module F:\Program Files\UGSⅡ\NX 6.0\ugii\dbghelp.dll 6c60000 118000 6c2195b-4ee28426-94c867b0-a41b7b32-1 version = 6.5.3.7
Loaded module C:\Windows\System32\wshtcpip.dll 752b0000 5000 4f115ec-4a42ecd4-73bb3bc-dcb39b0e-2 version = 6.0.6001.18000
Loaded module C:\Windows\system32\rasadhlp.dll 70e40000 6000 ef7ce7f6-474cca80-1b403c8b-2363dece-2 version = 6.0.6000.16386
Loaded module C:\Windows\system32\icmp.Dll 743d0000 3000 5bc26ad9-4dd6a6f7-d65e8aa7-9d54dcbb-2 version = 6.0.6000.16386
Loaded module C:\Windows\System32\winrnr.dll 71810000 8000 503c6eaa-471e0365-f3fc8aa0-f882fbd7-2 version = 6.0.6000.16386
Loaded module C:\Windows\System32\mswsock.dll 755f0000 3b000 4ac8dc12-4ac7e86b-5d739c9a-1291708d-2 version = 6.0.6001.18000
Loaded module C:\Windows\system32\pnrpnsp.dll 71610000 12000 9978701f-42e80098-accff788-2f7bd8e2-2 version = 6.0.6001.18000
Loaded module C:\Windows\system32\napinsp.dll 71820000 f000 40732fc5-438f8838-8798eaad-48e07b4c-2 version = 6.0.6001.18000
Loaded module C:\Windows\system32\dhcpcsvc6.DLL 757c0000 21000 fce55fab-47f11f3f-d0041c9d-d27bb1bc-2 version = 6.0.6001.18000
Loaded module C:··············
如果哪位高手知道的话,请告知在下!
再次谢谢了!!
发表于 2008-12-5 13:32:44 | 只看该作者
# Processors :- 2
Memory       :- 2045Mb
Free  Swap   :- 3079Mb
License Error: -15
Feature:       server_id
Feature:       server_id
如果哪位高手知道的话,请告知在下!
再次谢谢了!!
您正在看的文章来自中国N维酷吧-爱酷吧,爱学习! https://www.nwk8.cn,原文地址:https://www.nwk8.cn/read.php?tid=25157
发表于 2009-11-27 18:51:05 | 只看该作者
我和你一样的问题,不知道如何解决,打算换回XP
GMT+8, 2025-9-17 22:11 , Processed in 0.026113 second(s), 11 queries , Gzip On, Redis On.
