查看: 18975|回复: 9
【求助】How to Use CATIA V5R7 open the CATIA V4R1.9 files?
发表于 2003-5-30 16:29:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The issue same as the title.
发表于 2003-5-30 17:10:52 | 只看该作者
May be open it directly! *.model *.session Just try it. But you will lost special(may be)
发表于 2003-6-2 09:43:26 | 只看该作者
I do test several times, I believe I can open, but the file for view only, and can not do any operation and revise, also can not save as the v5 file, how to do? (I have no the CATIA V4 software, and the file came from the parent company)
发表于 2003-6-2 10:28:54 | 只看该作者
Copy All the V4 *.model
New a V5 *.CATPart
Paste to CATPart
Save
发表于 2003-6-2 13:38:56 | 只看该作者
Afternoon, Banzhu
For OS problem, I can write my issues in English only.
Thanks your reply, but I still can not convert the old V4 file into the V5.
Appreciate you can check my steps as below: (point out where is the problem.)
1. Open the CATIA V5R7 software;
2. “File->open…” Select directory and open the file: M1846.model (the file version is CATIA V4)
3. At the current status, I can view the model, (rotate, move the model as the different view), but I can not do any revise, operation…etc.
For the step1 to step3, I try it last week, then base your advise, I continue…
4. Select the parts, “Edit->Copy”
5. “File->new” and select the “part”,   “Edit->paste”
Then the system pop out a warming notes: Migration as Result of the Mock-up Solid *Sol1:- Creation of the CGR file in the directory where is the model is stored.”
6. Then, I can find a new file named “M1846_SOL1.cgr” is the same directory.
7. Try to open the file, the system pop out a warming dialogue “Invalid format for open. Use Insert                     ->Existing Component. Click “OK” to close the dialogue.
8. Click “Insert”, can’t find the item as “Existing Component”
9. Click “file->new”, select “product” click “insert”, now I can find the item as the “Existing Component”, click it, and the system has no any response.
10. Double click “applications”(at the up left corner), system pop out the file selection dialogue. Select “M1846_SOL1.cgr” file. Now, the part seems import in.
But I believe the part just be thought as a component in a assembly product, I still can’t do any revise, can not output the part into a “.igs” file. More advantage than before, I can do add some new parts in the product. I do hope you can understand my mean. Thanks a lot.
发表于 2003-6-2 21:30:24 | 只看该作者
Try Paste Special then select Paste with Special(means With some History)
Let us know your resault pls
发表于 2003-6-3 08:53:26 | 只看该作者
Cancelled.
发表于 2003-6-3 08:54:44 | 只看该作者
The result as the attached DOC file (ziped).
Thanks,
发表于 2003-6-6 17:01:38 | 只看该作者
for 3d model :
select *MASTER---COPY,NEW ---PART----PASTE SPECIAL---AS  ---PART----PASTE SPECIAL---AS RESULT----UPDATE,OK。
FOR DRAWING:
SELECT *DRAFT---COPY。。。。。。。。。,SOME TXT MAY BE CHANGED。
IF YOU CANNOT DO PASTE AS RESULT:
SELECT *MASTER,THEN THE “GEOMETRY CHECK“WILL BE AVAILABLE,CLICK TO CHECK。“”“”ONLY THE SYMBOL =G“”“”CAN BE PASTED THE SYMBOL =G“”“”CAN BE PASTED。
发表于 2003-6-6 17:02:56 | 只看该作者
图片搞错了!
GMT+8, 2025-4-22 22:18 , Processed in 0.026604 second(s), 11 queries , Gzip On, Redis On.
