查看: 15793|回复: 0
[求助] 请版主,高手帮我解释一段后处理,谢谢!
发表于 2008-12-21 20:10:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
版主,高手们,我现在有一段Master cam 的后处理(Wire cut ),能否帮我解读一下,是关于穿线,剪线的,谢谢了。
# NC output, wire thread and cut
pthread1     # Thread wire
             wirethd = mi4
             if wirethd = one, n, "/ M00 (THREAD WIRE)", e
             if wirethd = zero, n, "M20", e
                                n, "M78",e
                                n, "M78",e
             if water = 1, n, "M80", e
             if wire = 1, n, "M82", e
             if power = 1, n, "M84", e
             wirein = one
pthread      # Thread wire
             test = zero
             if wirein = zero, test = one
             if wirethd2 = zero, test = zero
             if test = one, pthread1
pbreak2      # Break wire
             if power = 1, n, "M85", e
             if wire = 1, n, "M83", e
             if water = 1, n, "M81", e
             n, "/ M00    (CUT WIRE)", e
pbreak1      # Break wire
             wirethd = mi4
             if wirethd = zero, n, "M21", e
             if wirethd = one, pbreak2
             wirein = zero
pbreak       # Break wire
             test = one
             if wirein = zero, test = zero
             if reposflag = zero, test = zero
             test2 = zero
             if prv_mi5 = two, test2 = test2 + one
             if savsubno = subno, test2 = test2 + one
             if subtyp <> zero, test2 = test2 + one
             if test2 = 3, test = zero
             if prv_mi5 = one, test = zero
             test3 = zero
             if gcode = 1003, test3 = test3 + one
             if wirein = one, test3 = test3 + one
             if test3 = two, test = one
             if test = one, pbreak1
pthreadcan   # Thread wire, cantext
             if wirethd2 = one, pthread
pbreakcan    # Break wire, cantext
             if wirein = one, pbreak1
GMT+8, 2025-4-26 05:23 , Processed in 0.018903 second(s), 11 queries , Gzip On, Redis On.
