查看: 21180|回复: 14
【分享】Proe上二次开发好的2个例子
发表于 2003-6-3 13:33:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
国外下载的
Pro/E Version: 2000i2, 2001
Description: This Pro/ToolKit application (DrawingOpener) allows the user to open drawings of the current part or assembly. Simply click, and the application will retrieve into RAM all drawings which contain the currently active part or assembly. DrawingOpener will also work with family tables instances.
Version 1.2
License: Shareware
OS: Windows 95/98/Me/NT/2000/XP
发表于 2003-6-3 13:36:37 | 只看该作者
PARAMFILEOPENER POPULAR!    6/8/2002 2:37:00 AM
Description: This Pro/ToolKit application allows the user to open almost any type of file whose name is specified in a Pro/Engineer parameter. The application is configurable to open your desired file type, with your desired application. You can also configure the application to read the parameter of your choice - no need to rename existing parameters. Note that this application WILL work in Part mode, Assembly mode, and Drawing Mode. It is compatible with Pro/ENGINEER 2000i2 and 2001.
Version 1.2
License: Freeware
希望对大家有所帮助
发表于 2003-6-3 14:51:50 | 只看该作者
Thanks
发表于 2003-6-3 15:02:18 | 只看该作者
下不了啦,,,能提供源出处吗?
谢谢啦,我推选你当斑竹啦。。。
发表于 2003-6-3 16:11:28 | 只看该作者
为什么不能下?
发表于 2003-6-3 16:13:02 | 只看该作者
将地址栏的https://icax.org/改为https://icax.org/就可以了
发表于 2003-6-3 16:24:22 | 只看该作者
yeah,你说对了,加分,^_^
发表于 2003-6-4 10:51:33 | 只看该作者
Thanks
发表于 2007-2-8 21:45:03 | 只看该作者
是好东东,谢谢!
发表于 2007-4-13 17:00:44 | 只看该作者
我要下载
GMT+8, 2025-4-6 15:19 , Processed in 0.082672 second(s), 14 queries , Gzip On, Redis On.
