查看: 16810|回复: 7
[资料] PCB材料类型及选用,希望对大家有用
发表于 2009-1-19 11:45:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
应CCTV老大(看在服务周到的份上能否给加个分鼓力啊 )和大家的要求,特翻译和补充资料如下:
PCB基板材料,按照材料的性质来划分,基本上可以分为纸基印制板、 环氧玻纤布印制板、复合基材印制板、特种基材印制板等多种基板材料
(1)纸基印制板 这类印制板使用的基材以纤维纸作增强材料,浸上树脂溶液(酚醛树脂、环氧树脂等)干燥加工后,覆以涂胶的电解铜箔,经高温高压压制而成。按美国ASTM/NEMA(美国国家标准协会/美国电气制造商协会)标准规定的型号,主要品种有FR-1FR-2FR-3(以上为阻燃类XPCXXXPC(以上为非阻燃类)。全球纸基印制板85%以上的市场在亚洲。最常用、生产量大的是FR-1XPC印制板。
(2)环氧玻纤布印制板 这类印制板使用的基材是环氧或改性环氧树脂作黏合剂,玻纤布作为增强材料。这类印制板是当前全球产量最大,使用最多的一类印制板。在ASTM/NEMA标准中,环氧玻纤布板有四个型号:G10(不阻燃)FR-4(阻燃)G11(保留热强度,不阻燃)FR-5(保留热强度,阻燃)。实际上,非阻燃产品在逐年减少,FR-4占绝大部分。
(3)复合基材印制板 这类印制板使用的基材的面料和芯料是由不同增强材料构成的。使用的覆铜板基材主要是CEM(composite epoxy material)系列,其中以CEM-1CEM-3最具代表性。CEM1基材面料是玻纤布,芯料是纸,树脂是环氧,阻燃;CEM-3基材面料是玻纤布,芯料是玻纤纸,树脂是环氧,阻燃。复合基印制板的基本特性同FR-4相当,而成本较低,机械加工性能优于FR-4
(4)特种基材印制板 金属基材(铝基、铜基、铁基或因瓦钢)、陶瓷基材,根据其特性、用途可做成金属(陶瓷)基单、双、多层印制板或金属芯印制板。
Laminated materials are designated with FR (flame resistant) and G grades. FR–1 is the least flame resistant, and FR–5 is the most. G10 and G11 have special characteristics as described in Table 17–1.Do not use FR–1. There are many examples of boards with burned spots, where high wattage components have heated a section of the board for a period of time. This grade of PCB material has more in common with cardboard than anything else.FR–4 is commonly used in industrial-quality equipment, while FR–2 is used in high-volume consumer applications. These two board materials appear to be industry standards.Deviating from these standards can limit the number of raw board material suppliers and PCB houses that can fabricate the board because their tooling is already set up for these materials. Nevertheless, there are applications in which one of the other grades may make sense. For very high frequency applications, it may even be necessary to consider Teflon or even ceramic board substrate. One thing can be counted on, however: the more exotic the board substrate, the more expensive it will be.In selecting a board material, pay careful attention to the moisture absorption. Just about every desirable performance characteristic of the board will be negatively impacted by moisture. This includes surface resistance of the board, dielectric leakage, high-voltage breakdown and arcing, and mechanical stability. Also, pay attention to the operating temperature.High operating temperatures can occur in unexpected places, such as in proximity to large digital ICs that are switching at high speeds. Be aware that heat rises, so if one of those 500-pin monster ICs is located directly under a sensitive analog circuit, both the PCB and circuit characteristics may vary with the temperature.After the board substrate material has been selected, the next decision is how thick to make the copper foil laminated to it. For most applications, 1-ounce copper is sufficient.If the circuit consumes a lot of power, 2-ounce may be better. Avoid -ounce copper, because it tends to break between the trace and the pad.
薄板材料被指定以FR(阻燃性)和G等级FR-1阻燃性最低,FR-5最高.G10和G11属于特殊用途等级.FR-1板子上的布高压元器件的位置因高压元件发热易出现烧伤点,这个阻燃等级的PCB板的性能合普通纸板有很大的共性,所以使用需慎重.FR-4被广泛用在工业级质量要求的设备上,FR-2 高电性,在普通家电中使用较多.----, 对于一些高频应用,可以考虑聚四氟乙
烯(TEFLON)或者陶瓷做底层,尽管如此,板材材料越特殊,成本也越高,选材时要考虑潮湿的影响,因为潮湿会降低板子的各种性能.包括板子表面阻抗的,电介质泄漏,高压损耗合或电弧,合机械稳定性.同样,需要关注工作温度.在一些意想不到的地方会出现高的工作温度,比如靠近处于高速运算中的大的数字集成芯片的地方.请注意发热的问题,如果一个500个pin脚的超级芯片被放置在一个敏感的模拟电路下方时,PCB和电路的特性都会因为温度而变化.当板子基材选定后,下面就是决定覆铜层的厚度.在大多数情况下,1-盎司铜就足够了.如果电路功耗较大,那么2-盎司也许会更好一些.避免用0.5盎司铜,因为这会导致铜皮联通不可靠.
[ 本帖最后由 huayuan008 于 2009-1-20 14:36 编辑 ]
发表于 2009-1-19 14:06:57 | 只看该作者
樓主能翻譯一下嗎?
发表于 2009-1-19 15:30:01 | 只看该作者
I can't read english.
发表于 2009-1-20 12:51:48 | 只看该作者
你不知道这里中国人多吗?
发表于 2009-1-20 12:58:52 | 只看该作者
看起来有点费劲
发表于 2009-1-20 13:00:20 | 只看该作者
不管怎样还是谢谢!
发表于 2009-1-20 13:00:27 | 只看该作者
   understand   understand
发表于 2009-1-21 11:26:18 | 只看该作者
JXCCTV版主,我已经翻译了...
GMT+8, 2025-1-31 10:25 , Processed in 0.029310 second(s), 10 queries , Gzip On, Redis On.
