查看: 16780|回复: 5
ATTENTION: Mastercam V9.1 Warning !
发表于 2003-6-5 00:52:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
From CNC Software:
Version 9.1 Warning
Anyone using MasterCAM V9.1 and using Tool Plane / Construction Plane with the Working Coordinate System and set to a plane other than 'top' should read this warning:
The NCI 100 line for subsequent points in planar drilling operations in V9.1 is reporting incorrect tool plane matrix values, resulting in an incorrect tool plane matrix and incorrect tool vectors in the post. The results will vary depending on the post, but certainly improper angles and/or mapped coordinates could be output. The bug has been logged in the bug database.
Anyone using Mastercam V9.1 WCS for multiaxis machine programming or 2 1/2 axis drilling of more than 1 point per operation should be advised of this issue.
If you are using the WCS, but have question 164 set to n in your post, or are using a post like Mpmaster that turns off rotary moves if all operations are in the top plane, you are not likely to encounter this problem.
This issue will be corrected in V9.1 Service Pack 1 when released.
发表于 2003-6-6 01:05:18 | 只看该作者
Archi wrote:
From CNC Software:
  Version 9.1 Warning
  Anyone using Mastercam V9.1 and using Tool Plane / Construction Plane with the Working Coordinate System and set to a plane other than 'top' should read this warning:
这里应该是中文论坛吧
发表于 2003-6-7 11:02:23 | 只看该作者
有理!!!!!!!!!!!!!
发表于 2003-6-8 12:11:06 | 只看该作者
9.1正版的虫都咬死你
今期的9.1d版大家别用了
发表于 2003-6-9 09:57:12 | 只看该作者
zl wrote:
9.1正版的虫都咬死你
  今期的9.1d版大家别用了
沒錯啦,不些功能還是不錯的啦. 頂::F::6
发表于 2003-6-14 22:14:29 | 只看该作者
DB不DB版到无所谓~~
可是别拿一些鸟语在这里说~~太深奥
GMT+8, 2025-4-11 09:21 , Processed in 0.024903 second(s), 13 queries , Gzip On, Redis On.
