查看: 19154|回复: 0
ANSYS中如何得到模型的总体积
发表于 2009-2-21 17:19:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
进入ANSYS主菜单General Postproc->Element Table->Define Table,在Element Table Data窗口中选择Add,在Define Additional Element Table Items中选择单元的几何信息(Geometry->单元体积(Elem Volume VOLU
结果弹出警告对话框如下:
Item VOLU has not been stored in the database.
The ETAB command is ignored.
请问高手这是怎么回事啊?
GMT+8, 2025-4-19 23:32 , Processed in 0.019815 second(s), 11 queries , Gzip On, Redis On.
