查看: 24654|回复: 14
[求助] 怎么用pro/toolkit创建一个拉伸特征啊!
发表于 2009-3-10 16:06:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠:
       跪求一个完整的用pro/toolkit在pro/e2.0上创建拉伸特征的的C源程序,只要能创建一个正方形即可。
      先谢谢啦!!
发表于 2009-3-10 18:36:03 | 只看该作者
看 李世国的书,上面很详细,
发表于 2009-3-10 22:03:37 | 只看该作者
FUNCTION : UsrCreateExtrudeFeat(创建拉伸特征)
void UsrCreateExtrudeFeat(
       double depth_value,    //(In)拉伸深度
                         ProGeomitem SketchPln, //(In)草绘平面
                         ProGeomitem RefPln1, //(In)参照平面1
                         ProGeomitem RefPln2,  //(In)参照平面2
                         int ProtrusionOrCut, //(In)特征类型
       int index,             //(In)草图序号
        double *dimValue)     //(In)直径
ProError         status;
    ProSolid solid;
    ProSection section;
    ProElement elem_tree, element, stdsec_elem, setup_elem,
  depth_elem, depthfrom_elem, depthto_elem, secpln_elem;
    ProFeatureCreateOptions opts[1];
    ProModelitem modelitem;
    ProSelection sel;
    ProFeature feature;
    ProErrorlist errors;
int ivalue;
int win_id;
    ProMdlCurrentGet((ProMdl*)&solid);
    为特征树分配内存
    ProElementAlloc(PRO_E_FEATURE_TREE, &elem_tree);
    向特征树添加特征类型元素
    UsrElemtreeElementAdd(PRO_E_FEATURE_TYPE,elem_tree,
       &ProtrusionOrCut,PRO_VALUE_TYPE_INT,&element);
    向特征树添加特征形式元素
ivalue=PRO_EXTRUDE;
    UsrElemtreeElementAdd(PRO_E_FEATURE_FORM,elem_tree,
       &ivalue,PRO_VALUE_TYPE_INT,&element);
    向特征树添加标准截面元素
ProElementAlloc(PRO_E_STD_SECTION, &stdsec_elem);
    ProElemtreeElementAdd(elem_tree, NULL, stdsec_elem);
    向特征树添加标准截面设置元素
    ProElementAlloc(PRO_E_STD_SEC_SETUP_PLANE, &setup_elem);
    ProElemtreeElementAdd(stdsec_elem, NULL, setup_elem);
    向特征树添加草绘平面元素
  ProElementAlloc(PRO_E_STD_SECTION_PLANE, &secpln_elem);
  ProElemtreeElementAdd(setup_elem, NULL, secpln_elem);
    向特征树添加草绘平面设置元素
  ProSelectionAlloc(NULL, &SketchPln, &sel);
     UsrElemtreeElementAdd(PRO_E_STD_SEC_PLANE,secpln_elem,
       &sel,PRO_VALUE_TYPE_SELECTION,&element);
  ProSelectionFree(&sel);
    向特征树添加草绘平面视图方向设置元素
ivalue=PRO_SEC_VIEW_DIR_SIDE_ONE;
    UsrElemtreeElementAdd(PRO_E_STD_SEC_PLANE_VIEW_DIR,secpln_elem,
    向特征树添加草绘平面定位方向设置元素
ivalue=PRO_SEC_ORIENT_DIR_UP;
    UsrElemtreeElementAdd(PRO_E_STD_SEC_PLANE_ORIENT_DIR,secpln_elem,
    向特征树添加草绘平面参照基准设置元素
ProSelectionAlloc(NULL, &top, &sel);
    UsrElemtreeElementAdd(PRO_E_STD_SEC_PLANE_ORIENT_REF,secpln_elem,
    向特征树添加标准截面草绘方法元素
ivalue=PRO_SEC_SKETCH;
    UsrElemtreeElementAdd(PRO_E_STD_SEC_METHOD,setup_elem,
    创建非完全特征
    status=ProMdlCurrentGet((ProMdl*)&solid);
if(status!=PRO_TK_NO_ERROR)return(status);
ProMdlToModelitem(solid, &modelitem);
    ProSelectionAlloc(NULL, &modelitem, &sel);
    opts[0] = PRO_FEAT_CR_INCOMPLETE_FEAT;
    ProFeatureCreate(sel, elem_tree, opts, 1, &feature, &errors);
    从数据库中获得截面元素
UsrSectionGet(&feature,PRO_E_STD_SECTION, &section);
    构建和求解截面
    UsrSectionBuild(&RefPln1, &RefPln2, section,index,dimValue);
    将草绘器元素添加到特征元素树中
    UsrElemtreeElementAdd(PRO_E_SKETCHER,stdsec_elem,
       &section,PRO_VALUE_TYPE_POINTER,&element);
    拉伸深度定义
    ProElementAlloc(PRO_E_STD_EXT_DEPTH, &depth_elem);
    ProElemtreeElementAdd(elem_tree, NULL, depth_elem);
    起始面定义
    ProElementAlloc(PRO_E_EXT_DEPTH_FROM, &depthfrom_elem);
    ProElemtreeElementAdd(depth_elem, NULL, depthfrom_elem);
    拉伸深度类型(给定深度值)
ivalue=PRO_EXT_DEPTH_FROM_BLIND;
    UsrElemtreeElementAdd(PRO_E_EXT_DEPTH_FROM_TYPE,depthfrom_elem,
    深度值设置
    UsrElemtreeElementAdd(PRO_E_EXT_DEPTH_FROM_VALUE,depthfrom_elem,
       &depth_value,PRO_VALUE_TYPE_DOUBLE,&element);
    终止面定义
    ProElementAlloc(PRO_E_EXT_DEPTH_TO, &depthto_elem);
    终止面类型
ProElemtreeElementAdd(depth_elem, NULL, depthto_elem);
    终止面深度值
ivalue=PRO_EXT_DEPTH_TO_NONE;
    UsrElemtreeElementAdd(PRO_E_EXT_DEPTH_TO_TYPE,depthto_elem,
    向特征元素树添加新的深度定义元素后重定义特征
    ProFeatureRedefine(NULL, &feature, elem_tree, opts, 1, &errors);
    status=ProSectionFree(&section);
重新调整模型,使其在当前窗口完全显示
ProWindowCurrentGet(&win_id);
ProWindowRefit(win_id);
FUNCTION : UsrSectionGet()
从指定特征的元素树中选出草绘器(PRO_E_SKETCHER)元素之值
int UsrSectionGet(ProFeature *feature, //(In)  特征句柄
        int elemId,   //(In)  截面标识符
        ProSection *section) //(Out) 截面元素
    ProError status;
    ProElempath path;
    ProElempathItem path_items[2];
    ProValue value;
    ProValueData value_data;
    *section = NULL;
//设置特征截面元素的路径
    path_items[0].type = PRO_ELEM_PATH_ITEM_TYPE_ID;
    path_items[0].path_item.elem_id = elemId;
    path_items[1].type = PRO_ELEM_PATH_ITEM_TYPE_ID;
    path_items[1].path_item.elem_id = PRO_E_SKETCHER;
    ProElempathAlloc(&path);
    ProElempathDataSet (path, path_items, 2);
//从指定特征中得到路径为path的元素值(非透明的ProValue对象)
    status =ProFeatureElemValueGet(feature, path, &value);
    if(status != PRO_TK_NO_ERROR)
  return(0);
    ProElempathFree(&path);
    //从非透明的ProValue对象得到用户可以访问的数据对象ProValueData
    ProValueDataGet(value, &value_data);
//获得截面元素指针
    *section = (ProSection)value_data.v.p;
    return(1);
粉红色的这个程序是不是有问题啊?这就是李世国书上的,但拉伸出不来啊?
发表于 2009-3-10 22:31:57 | 只看该作者
各位大侠,帮帮忙吧!实在想不出来啊!发个程序过来让我参考参考吧!谢谢啦!!
发表于 2009-3-24 10:53:55 | 只看该作者
至少在4.0上有问题,
测试一下可以发现:*section ==NULL;为真。
所以程序会自动退出。
处理的办法是:(注册运行之后)在点击按钮CreateFeature(bolt)之前需要——Applications->Legacy->Feature->Done,然后点击上述按钮就可以创建特征。
至于怎么用修改程序,还在摸索中.........。要是哪位高人知道,请指点。
发表于 2009-4-8 11:02:54 | 只看该作者
我这里有个 Proe 2001 下 VC6 做的非常简陋的 拉伸 加料特征程序。
仅供参考。看不懂别骂我。
1, C++的代码;
2,没有注释。
发表于 2009-4-8 11:03:48 | 只看该作者
附加代码在此
发表于 2009-4-8 11:37:29 | 只看该作者
李世国的例子特征创建元素树是采用2001的结构,当然不能在野火上运行,参照野火拉伸特征元素树修改一下就可以了。
发表于 2010-3-7 22:45:27 | 只看该作者
具体怎么改啊 楼上的 可以把你改的代码我参照一下吗 谢谢你   我QQ601698998  有空可以交流一下
发表于 2010-3-24 23:49:45 | 只看该作者
学习中。。。。。
GMT+8, 2025-9-18 15:19 , Processed in 0.091007 second(s), 13 queries , Gzip On, Redis On.
