查看: 25699|回复: 7
[求助] solidworks文件 在文件夹里(64位XP下)如何显示缩略图
发表于 2009-3-11 18:59:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近更换了一台电脑,新装的XP是64位的,SOLIDWORKS是09版.但是各solidworks文件 在文件夹里不是显示缩略图,连solidworks图标都不是.(在32位XP下均能显示缩略图.),是不是有什么系统设置不对?有什么办法能解决不?没有缩略图,找零部件还正有点不方便哦...求助求助~~~~
发表于 2009-3-12 22:39:51 | 只看该作者
哇呀...没有人和我一样碰到这个问题呀...郁闷哦...
发表于 2009-3-13 00:21:40 | 只看该作者
1. Click start -> run ->Regedit
2. Go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
3. Right mouse button click the blank place of right -> select New -> DWORD Volume -> rename it as ThumbnailSize -> double click it and enter the volume as 100 (we can enter a volume form 6 to 256) -> Close it.
4. Check the size of the thumbnail. The preview is clear and bigger than before.
参与人数 1技术 +1 大米 +10 收起 理由
Francis + 1 + 10 樂于助人
发表于 2009-3-13 00:23:05 | 只看该作者
The thumbnail graphics are simply icons cached with the file and displayed in Windows Explorer by Microsoft. Microsoft decides when to update the cached icon information, and therefore when to change the display of the icons. In this case, it may be that access to the file is needed to get the icons to update. For example, selecting the file in Windows Explorer or opening and saving the file usually fixes the problem.  Sometimes the registry location where the icon information is cached becomes corrupted. We do not know the cause of this problem. To see if this is the case, run the "regedit" command, and then expand HKEY_CLASSES_ROOT. Under HKEY_CLASSES_ROOT, there must be a SldAssem.Document folder and an SLDPart.Document folder. Each folder must have a "shellex\iconhandler" folder. If the "shellex" or "iconhandler" folder is missing, the thumbnail graphics will not function.  A reboot will often be required to see the changes.
发表于 2009-3-13 00:24:41 | 只看该作者
To resolve this issue, un-register and reregister "sldwinshellextu.dll"
This dll should be present in the SolidWorks installation directory (..\Program Files\SolidWorks)
To un-register and reregister this dll use the following command respectively from the command prompt:
regsvr32 /u  sldwinshellextu.dll
regsvr32  sldwinshellextu.dll
发表于 2009-3-14 12:44:53 | 只看该作者
哇塞...是单位电脑有这个问题...周一去试试....
发表于 2009-3-18 19:58:09 | 只看该作者
还是没解决...自己顶起...继续期待...
发表于 2009-3-19 01:23:01 | 只看该作者
我遇到过此种现象,怎么弄都不行后来从装了sw2009就好了,不知为何?
GMT+8, 2025-10-21 15:27 , Processed in 0.027004 second(s), 14 queries , Gzip On, Redis On.
