查看: 16526|回复: 5
[讨论] 二种ACTION的实现
发表于 2009-3-30 20:16:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
第一种:
static UF_MB_cb_status_t testCB(
    UF_MB_widget_t                     widget,
    UF_MB_data_t                  client_data,
    UF_MB_activated_button_p_t call_button )
uc1601("testCB",1);
  char partName[]="d:\\test.prt";
  tag_t partTag=NULL_TAG;
     UF_PART_new(partName,1,&partTag);
  if(partTag==NULL_TAG)
   uc1601("false!",1);
  else
   uc1601("here is a tag now",1);
return UF_MB_CB_CONTINUE;
UF_MB_action_t actionTable[]=
  {"test",testCB,NULL},
  {NULL,NULL,NULL}
发表于 2009-3-30 20:17:55 | 只看该作者
第二种:
static UF_STYLER_callback_info_t CHANGE_cbs[CHANGE_CB_COUNT] =
{UF_STYLER_DIALOG_INDEX, UF_STYLER_OK_CB           , 0, CHANGE_OnOk},
{UF_STYLER_DIALOG_INDEX, UF_STYLER_APPLY_CB        , 0, CHANGE_apply_cb},
{CHANGE_ACTION_0       , UF_STYLER_ACTIVATE_CB     , 0, CHANGE_CreateNewPart},
{UF_STYLER_NULL_OBJECT, UF_STYLER_NO_CB, 0, 0 }
static UF_MB_styler_actions_t actions[] = {
    { "NewPart.dlg",  NULL,   CHANGE_cbs,  UF_MB_STYLER_IS_NOT_TOP },
            { NULL,  NULL,  NULL,  0 } /* This is a NULL terminated list */
int CHANGE_CreateNewPart ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
     /* ---- Enter your callback code here ----- */
         uc1601("OnButton_CreatePart",1);
         tag_t partTag;
                 uc1601("false!",1);
     UF_terminate ();
    /* Callback acknowledged, do not terminate dialog */
    return (UF_UI_CB_CONTINUE_DIALOG);
    /* or Callback acknowledged, terminate dialog.    */
    /* return ( UF_UI_CB_EXIT_DIALOG );               */
发表于 2009-3-30 20:20:47 | 只看该作者
很简单的测试,都是要创建一个新的PART,第一段代码用
        UF_MB_add_actions(actionTable);
无法得到预期的结果;而用UISTYLER的:
           UF_MB_add_styler_actions ( actions )就可以实现
发表于 2009-3-30 20:22:21 | 只看该作者
用UF_MB_add_actions(actionTable)的话一些命令会无法实现,什么原因?
发表于 2009-3-30 20:38:18 | 只看该作者
用UF_CALL查到了原因。大家试试看
发表于 2009-4-2 14:10:12 | 只看该作者
,我都是第一种方法来做开发,经过N个项目的检验,没有发现哪个命令不能用。
GMT+8, 2025-4-30 17:48 , Processed in 0.024013 second(s), 11 queries , Gzip On, Redis On.
